0 Members and 554 Guests are viewing this topic.
T-1000
Well, my advice - please read http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg407201/#msg407201 all over again and try to understand what was said there.
Also there is some insider information who wished to stay anonymous - the coils themselves are correct in schematic and same as in akula0083 design which you seen powering up to few kW of load... ;) This made akula very nervous on someone.
Cheers!
Jeg
Quote from: 00 on June 22, 2014, 03:58:53 AM
to fetch energy from ground we must have a non inductive coil that is cw first layer and ccw 2nd layer or ccw first layer and cw 2nd layer. the 3rd and 4th and 5 th and 6 th layers must be inductive so they convert the ground charges into amperes under the influence of magnetic primary coil. the coaxial fucnction is  just to pump charges from ground and accumulate in non inductive first two layers of output coil. since we know rule of transformer with more load  more input is required. this input is provided with ground and the ions  gets accelerated due to magnetic field effect from the primary inductive coil. thats how it works.
00
This description fits to me better until now. My opinion is that first we have to find the working principal and then to calculate the coils and everything else. If we just try to copy paste the output coil without taking in account the frequencies involved then for sure we are going to fail. As you know from your Tesla coil builds the length of the secondary is what counts more in relation of course with the involved frequency.
Well, my point of view is that we treat the whole construction like we build a common Tesla coil. Instead of capacitor discharging through a Tesla coil, we introduce a current pulse straight to the coil, and then we force it to oscillate to the induced frequency. If we just let a low frequency current pulse to load the output coil then after each pulse the field of the coil will collapse giving back a peak. But if we introduce a frequency to this positive current pulse, then the collapsing energy will repeat itself again and again until the current pulse cease down. Our first aim should be how to create a current pulse loaded with high frequency fluctuations. These loaded fluctuations have to reach zero in every cycle for better efficiency. (look tinsel's oscilloscope waveform) After we do this, then output coil will be constructed according to this frequency, and our aim then will be to build it in a way that its output will be high frequency current pulses instead ivoltage ones! At least this is the theory that I walk on, and my build is following these rules.
If you have any argues on this please express it so to make a constructive conversation.
Jeg
Quote from: T-1000 on June 19, 2014, 08:58:36 AM
http://www.realstrannik.ru/forum/39-kapanadze/134730-generatory-kapanadze-obshhaya-tema-2.html?start=3186#222905
First pumping energy into coils and then explosive pulses.
This is the most important for me, and i will support all the above theory by repeating again Leedskalnin's words.
The more times that the power signal attaches zero level, the more charges it gains from the outer environment i.e ground.
So, pump energy to the coil (positive or negative current pulses), and at the maximum current pulse fluctuate it with some thousands times in a second to take back some thousand times kick backs from the output coil. And these kickbacks are pure ground energy.
Ps. The only difference between acula's fuelless generator and Dally, is that the former drives the output coil straight with high current pulses from grid, and the latter gives them to the output coil inductively..
corry
Hi 00,
please, you want to confirm that the Chubinidze resonator is make so?
Thanks
NickZ
  quote: If you have any argues on this please express it so to make a constructive conversation.
                   end quote.
   The above statement is most important, as personal attacks are not the way to go.
And not one of us is certain of anything, as the proof is in the pudding, not in arguments.
  IF you feel that your point of view is correct, then build a device that will show that working idea. That is the most convincing way of  proving what you mean.
  Also, there may be more than one way to go on this, as each working self running device shown has been very different.
  MenofFather:  I agree with you concerning trying to build the more simpler and inexpensive device, hopefully by using already available materials where possible. Once the dust settles.
  T-1000:  Which Akula circuit are you talking about, which has several Kw of output?
Also which Akula circuit schematic were you thinking of, which the insider has commented as using the correct windings.
