0 Members and 533 Guests are viewing this topic.
d3x0r
I was trying to recruit your help, since you said you were interested in the same...
kinda like the girl that said "we're done' before we had even begun... as a last response it's gratefully the first :)
ya but please don't disrupt the thread then.
Edit: but please do join in... you said you were interested in replicating akula device....  Mazilli of high power is useful too... mine's all low amp stuff... but replacing that TL494 junk with junk a swappable capacitor and royer got some better results
Moves the series-resonsant frequency to the royer... since then the cap on the winding to the (heh) sausage coil is then useless and doesn't matter (just hampers the flow)
T-1000
Quote from: NickZ on June 22, 2014, 12:41:35 PM
  T-1000:  Which Akula circuit are you talking about, which has several Kw of output?
Also which Akula circuit schematic were you thinking of, which the insider has commented as using the correct windings.
In https://www.youtube.com/watch?v=pWfVnJ1sEms coils are same are made as in beginning of https://www.youtube.com/watch?v=-04V_NIrC0k and in http://realstrannik.ru/media/kunena/attachments/630/aquarium-1.gif ( http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=144#223930 )
Also the circut diagrams are only approximate except coils in that case. The nanosecond pulses do same thing as high voltage and high frequency range pulses in https://www.youtube.com/watch?v=qmirRN3O6Ko and https://www.youtube.com/watch?v=7jtjgAwXqGg
The primary generator is for transformer and is tuned for best output while nanosecond pulses are tuned to "ring the bell" in material (in ferrite or wire directly) and create resonant rotating magnetic field to XYZ axis from XY axis...
Cheers!
d3x0r
Quote from: T-1000 on June 22, 2014, 09:54:58 PM
Cheers!
The translate in chrome is different than translate.google.com ...
QuoteIt bifilar and work in this system. Everything else is trivia! Simply have to wind the coil and inductor. Inductor is too cunning and half wave across removable bifelyarki: unsure: Figures above diagram shows the coil obsalyutno correctly! Do not forget that all this should blow off the same way and proportioning even numbers. Harmonics can not be even, but just be sure to wind the coil as necessary. Otherwise will not work. Now I myself looking for another option GNSI. Since this (Belkin) that Dali used and ... Full fufel! Not this time, the bill of exchange GNSI: S Kacher Better then instead of this crap.
or
Quote from:  from translate.google.com
It bifilar and work in this system. Everything else is trivia! Simply have to wind the coil and inductor. Inductor is too cunning and half wave across removable bifelyarki Figures above diagram shows the coil obsalyutno correctly! Do not forget that all this should blow off the same way and proportioning even numbers. Harmonics can not be even, but just be sure to wind the coil as necessary. Otherwise will not work. Now I myself looking for another option GNSI. Since this (Belkin) that Dali used and ... Full fufel! Not this time, the bill of exchange GNSI Better then Kacher this crap instead.
Quote from: from bing translate
It is bifilâry and work in the system. The rest is trivia! We just need to properly wrap the coil and coil. Inductor too cunning and has a 1/2 wave all the demountable bifelârki: unsure: in the pictures above, the circuit coil is absolutely correct! Do not forget that it must wrap exactly the same and respect the aspect ratio of the even numbers. Harmonics may be odd, but just be sure to wrap the coil. Otherwise will not work. Now I'm looking for another option GNSI. As this (Belkin) that have used and Have ...Full fufel! Do not exchange this time GNSI: S better then kačer hreni instead.
so I guess 2 out of 3 translators agree that it's GNSI rather than kacher.
Jeg
Quote from: d3x0r on June 22, 2014, 05:03:39 PM
@general
Though now that I have this coil, and I have the kacher, and am considering replacing 494 with royer... The kacher is at a certain frequency because of the size of bobbin I use, and windings etc... and the topload affects the frequency also... so having tuned the filter to be less than or equal to this frequency, the kacher generates decent enough high voltage at like 200mA 14V...
And there's a series capacitor that makes a sertain resonant frequency on the output of toroid attached to the lower TL494... Need an answer from ruslan about how this relates to the kacher frequency.  (he has the same as skula device here... https://www.youtube.com/watch?v=pWfVnJ1sEms  notice high voltage windings, etc. [size=78%]) [/size]
now He's saying 'have to understand 'magnetic field'' which I'm sure we've all spent many hours searching the depths and widths of the net to find information about such... he somehow thinks he has a perspective that you can gleam from just this information...
D3 is it possible to say how much voltage your Katcher outputs?
Nick my friend I don't feel the need to prove anything, just need to make a conversation for the better understanding. Theory behind all this interests me more than to build something by guessing. And I have to say that you guys with your experience help a lot!
Well, my experimental setup creates a VHF around 27Mhz. I read yesterday the part of Tesla interview, who says that at high frequencies there are electromagnetic losses. Frequencies in the order of some decades of KHz are better for working with earth currents. I also saw in an akula replicator drawing that frequencies up to 70Khz are enough to make the job. So I am thinking to lower it down.
I want to use  Mazzilli combined with a TV yoke. The problem is that I can't put out voltages as high as 150V with just 12v battery input. I raised the input voltage up to 48v but the resistances of the circuit are getting hot like hell! I am thinking replacing them with higher wattage ones and try again.
00 does the output coil that you describe need to be in a total length of 1/4 of the wavelength of the main frequency? And please do you know if there is any reason for 3-6 layers to be shorter than the first two layers???
Tnks
Jeg
Jeg
Cheers!
T1000 is it possible to give us a link to know more about this rotating magnetic field? I can't visualize how a magnetic field can rotate while the coil is solenoid! As I know in solenoids the magnetic fluctuation happens across the length of the coil. What do you mean by rotation?
Great job Utopia, thanks a lot
