0 Members and 140 Guests are viewing this topic.
MenofFather
Quote from: itsu on September 19, 2012, 04:09:40 AM
Thanks 27Bubba, for opening this thread, i put here below the important posts i made in the other thread:
Thanks for the encouragement T, but as i already was experimenting with coax cable coils, i already was intriged by this selfrunner.
I have a hard time understanding the Russian drawings/text etc, but slowly more info is coming in English.
My first attention is to the main coil, and i came up with the following info (all CW):
L1 = 820t 0.25mm on 4.6cm former (white/orange leads)
L2 = 315t 0.65mm on top of L1     (magnet wire leads to caps)
L3 =  41t 5.9m Coax cable        (probably NOT RG58 as to my knowledge RG58 is always black coated)
L4 =  72t                        (combination of brown and blue cable) not sure what thickness.
I started building my coil and use:
cardboard former 5cm:
L1 690t 0.4mm  3.3mH / 14.5 ohm
L2 380t 0.6mm  1.5mH /  0.5 ohm
L3  41t (6m) 75 ohm coax shorted at 1 end
L4  i will use 70t of some kind of wire i have laying around.
Questions for me presently are:
How to create this 1-5ns pulse (my FG generates a 80ns pulse at best)
What is the amplitude of this nano pulse (5v?, 500v?, 5Kv?)
What is the frequency/amplitude and pulse shape on the L1 coil (match the resonance frequency of L2 tank coil?)?
Video to be seen here:  http://www.youtube.com/watch?v=MQUciCy9p3A&feature=youtu.be
I will try to get more to the point in the video's, thus shorther, in the follow ups if any.
Next will be to make some measurements on the coil when pulsed.
Regards Itsu
Thanks a lot for this info T-1000, so it means that even the creator of this device is not sure about the used wires of his coil.
Well, i finished my main coil and did some measurements/testing, including HV puls testing on the coax.
Here is the data on MY coil:
Cardboard former 5cm od
L1 690t, 0.4mm, 3.3mH, 14.5 Ohm, selfresonant (so no cap) on 2.4Mhz   (magnet wire)
L2 380t, 0.6mm, 1.5mH,  0.5 Ohm, resonance with 600nF cap on 5.071Khz (magnet wire)
L3  41t, 75 Ohm coax (tv) foam pe isolation, velocity 78%, 1 end shorted
L4  64t, stranded HV, 72uH, 0.8 Ohm, selfresonant (so no cap) on 4.8Mhz (Belden 24Kv HV cable)
Video of the testing here:  http://www.youtube.com/watch?v=utkIltw6WrU&feature=youtu.be
Great questions from d3x0r: "How about that toroid? is that a standard component from something?"
I also am looking for data on that toroid, like diameter, type/make, number of windings (4?), number of turns, wire used etc.
Anyway, parts are on order for the Main generator and for the pulser, it will take a while for them to arrive.
Regards Itsu
d3x0r,
from one of the diagramms i have printed out (i don't find it anymore on the forums, as it seems that data/diagramms are coming and going),  i have got this info:
Ferrite Ring probably 4cm od
Windings 1 and 2 are  3 turns 1.5mm
Windings 3 and 4 are 70 turns 0.6mm
Perhaps this can be confirmed by others.
Regards Itsu
"How to create this 1-5ns pulse (my FG generates a 80ns pulse at best)"
We do not know, that in Dally divice is 1-5 ns pulse. Maybe it and much more nanoseconds. In Topruslan divice pulse width is 50 ns.
"What is the amplitude of this nano pulse (5v?, 500v?, 5Kv?)"
Aplitude also we not know, but I guest, that about 700 V.
"What is the frequency/amplitude and pulse shape on the L1 coil (match the resonance frequency of L2 tank coil?)?"
Frenquency probarly 4.2 kiloherc about. Amplitude I guest about 200 volts. And probarly, yes, much frenquency L2 tank coil.
"I also am looking for data on that toroid, like diameter, type/make, number of windings (4?), number of turns, wire used etc."
About toroid, that I think. Primary turns have 20 windings (20x2). For nanopulser on secondary you must wound to get 100-150 volts. And for L1 coil you must wound to get 200 volts. ;)
MenofFather
Quote from: itsu on September 19, 2012, 04:39:31 AM
All,
Concerning the main generator (4.6Khz) toroid, i found this diagram which contains some data on it:
http://realstrannik.ru/media/kunena/attachments/1226/dally1.GIF
meaning:
But looking at the original pictures like Hoppy already mentioned, this does looks more like a commercial
toroid with much more wire on it.
While waiting on my parts to arrive, i was experimenting with a toroid i had laying around, see picture
(2 turns primary / 40 turns secondary), but was blowing up my MOSFET driver chips 4420 (MOSFETS IRF630) :-)
Questions:
# these 3 (or 2 turn) primary, act like a short to the MOSFET's, right?  Should there not be much more turns?
# these primaries (1a and 1b) should be CW and CCW, to work in this push/pull configuration, right?
# the secondaries (ii and iii) can be either CW or CCW, right?
Thanks,  Regards Itsu
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/115321/image//
This picture is from one man, not from Dally. Some people things, that that man replicate Dally divice.
Thaelin
   I know this will at first sound way off topic but it really is all about it. The ATX power
supply is near the same one I tried to power externally a long time ago. I opened the
case and tied my input wires directly to the high voltage cap connectors.
   The input was from my Bedini wheel. The re-captured power was fed directly to the
ATX and it did work. This was woefully under powered but it did work somewhat. It just
goes to show you can.  If using a ATX, just remember you are powering many other output
voltages other than 12V. Using a  110/220 to 12V only would be the best way to go. No
overhead to waste.
   I hope this helps someone here and not just a bunch of dribble.
thay
corry
Hi to All,
The Chubinidze resonator...
...is wound as in my drawing below?
Jeg
It really wasn't needed as 00 Utopia and D3 covered it, just attaching this simple AM receiver with diode demodulation. It is the basic way of extracting low acoustic frequencies from high frequency carriers.
