0 Members and 2047 Guests are viewing this topic.
MenofFather
Quote from: NickZ on June 24, 2014, 05:14:46 PM
  It would still be good for at least some of us to work together on one project to unravel this mistery. The only device that has been confirmed as working as shown, is the second Akula device. However, is there a confirmed schematic of that device???
No, here is no comfirmed schematic with all details, only one schematic, who akula post many times.
Only this schematics is from Akula:
T-1000
Quote from: stivep on June 24, 2014, 05:10:40 PM
I JUST DO NOT UNDERSTAND WHAT DO WE NEED RECTIFICATION FOR IN DALY?
Wesley
The answer is quite simple - on the output of bucking bifiler coils you will have FM like signal which will need to be rectified and filtered out in capacitors so computer PSU can have "normal" voltage input (it does not care for 50-60Hz AC or DC) as there are low frequency rectifier diodes inside of PSU. Also in regards of PSU on Dally case there was 300-350W computer power supply used and you can find its circuit diagrams in Internet quite easily.
Acca
 Here is the original clips that Ruslan studied from ....
Channel of   Канал пользователя chvalvit   "   chvalvit  "
http://www.youtube.com/watch?v=lEi24JG1WYI
http://www.youtube.com/watch?v=AFA-PajaJcc
http://www.youtube.com/watch?v=JtAW0eQUM7k
http://www.youtube.com/watch?v=lewnzZphPbo
Acca...[/font]
Acca
  Here is the latest  post by Ruslan  on russian forum in English link..
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Frealstrannik.ru%2Fforum%2F39-kapanadze%2F134930-ustanovka-ruslana-kulabuxova.html%3Fstart%3D216&edit-text=&act=url
And here is the link to russian Non -Pulse forum it's been around now for more than a year..
English ..
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Frealstrannik.ru%2Fforum%2F48-temy-freeenergylt-antanasa%2F81877-kak-nanosekundnyj-generator-sobrat-i-nastroit.html%3Flimitstart%3D0&edit-text=&act=url
Russian
http://realstrannik.ru/forum/48-temy-freeenergylt-antanasa/81877-kak-nanosekundnyj-generator-sobrat-i-nastroit.html?limitstart=0
Acca..
  exside writes:
1) TTL master clock 10-10MHz
2) Instead of trance with green scheme for TL, as the author has applied: Mostovoy car
amplifier based on TDA7560 4h77vt took one channel (this thing eats 2-4A to 14 volts)
loaded from the transformer halogen iron 25W (220v-12v) of course, loaded on
winding 12v. Parallel output winding is at 220 volts with this trance that
is already in the coil touches - in the amount of capacitor 204 Nana brute
(How to choose: look at the condenser coil with a separate oscillator (where now stands 235nan)
and by changing the frequency of the master oscillator + shift capacitors achieve
maximum amplitude in this particular resonant circuit also change the capacitance across the winding
220v) I in the coil resonant frequency of 6.8 kHz. Pronounced resonance! have
little sex ...
3) Scheme starting pulse shaper (on logic) for our nano generator anywhere
sinusoids (at the output) - is fed from the reference generator. The width of the trigger pulse to
IRF840, loaded on a mini trance given 1533ag3 adjustable.
So I turn on the first launch of an oscillator TTL, fed to an amplifier TDA7560 (divider connected to the input, but it is not the sine and square wave will 1.5x1.5 k) os put on the winding with a capacitor (which is separate, as the author) look 180 volts, throw bulb 25w 220Volt - lit from 180V)
Look at the output (the output winding by the author through a diode bridge with Conder wrapped ago) - there are 40 volts Breaks, driving frequency 6.8 kHz
Turn nano generator, and burn the lamp and oscillations on the output winding, see what's there.
As it was 40 volts and remains). Change the place of generation nano pulse 6.8 kHz sinusoid (beginning, middle, end, positive half wave, negative) - one hell only minor ringing in the formation of nano pulse at the output winding
(Voltage pulse nano - 750 volts even when loaded with cable shorted at the other end). Connect disconnect the ground (battery central heating) ---- one hell - NO FISH!,
true to the sound generator (frequency) of land has - changed little
After all this, it seems to me that the author still overclock resonance in a separate winding on the capacitor loaded - carried nano genenrator that its momentum at the right time (with the resonance frequency of the concurrent loop) it clocked and green trans - it's for a small buildup of circuit.
What I have not yet happening :(.
--- What are thoughts?
Why iznochalno (it was a chance to install) loaded by your nanogenerator nateslu through kaksial and other winding tsepanul Conder - and got hit?
But other sources Nanogenerators except he did not have!
Therefore I propose to achieve oscillations in the resonant circuit with Conder, only due to the pulse generator nano!, But we'll see ....
Thoughts are that the frequency needed higher. In Dalli, it's probably somewhere at least 25 kHz. And he pointed to his generator nanoimpulsov, ostsiliogramy on coaxial and an oscillator circuit nanosecond pulses, then could be something to try and give more precise.
Acca
Here are some photos of  nano generator that Rusaln has made.. The key is to understanding this is to understand
why one  needs to have all the separate bits to make the device work, to understand what Ruslan has disclosed  so far..
Acca..
