0 Members and 273 Guests are viewing this topic.
d3x0r
Quote from: Acca on June 25, 2014, 08:25:28 PM
Here are some photos of  nano generator that Rusaln has made.. The key is to understanding this is to understand
why one  needs to have all the separate bits to make the device work, to understand what Ruslan has disclosed  so far..
Acca..
TL494 and the hex nand gate chip have the different number of pins...
while the tl494 can generate a short duty cycle, and can be used instead of the nand gates, the nano pulse is really in the diode...
the transformer toroid in the nano pulser only has 2 windings, not 4
and with the choke in front of the pulser, it's going to be longer than the pulse of the transistor anyway... the work of nano-pulse actually comes from the DSRD.
In your second picture I only count 7 pins on a side of each chip; on the second picture the things you're indicating as mosfets are probably the voltage regulators.
in the first picture I do see 8 (16) pins and on the left chip, but only 7(14) on the right side.  ALso I only see 1 transistor, and no mosfets, and not a dual winding core...
think you may have mixed information
MenofFather
Ruslan use similar, wery similar sircuit, but not exatly like in this picture. He not use 74HC00, if I good remember. And he use one voltage stabiliser, how we see in video. And other diferences I see.
d3x0r
Quote from: stivep on June 24, 2014, 08:47:25 PM
The little disappointing is for me that when it comes to basics  or theory   I have no readers.
I'm writing to the thin air.It is like spending time  yelling into the forest.
Wesley
You're definitely not writing to thin air; I try to gleam as much as I can...
And speaking of theory, what's the theory of making a high current vs making a high voltage?
Doesn't a high voltage result in a high current?
Esp. as it relates to the akula-ruslan proposed schematic....
I guess from a perspective of inductive reactance... I dunno that's frequency dependant...
While I can see the sense of making high current low voltage, when that comes to driving an inductive load of much higher inductance and therefore higher resistance, can a low inductance coil pickup on a push-pull inverter even drive a larger coil?
Wouldn't it make more sense to make a higher voltage so you can get a higher current in the (L3) coil?   I mean it is just inductive, there's little capacitance except the parallel parasitic.....
While in the videos it looks like thre's just 3 turns of white wire exposed, there's also what looks like a layer of wire under the outer tape so it's at least a 1:1 and probably more like a 1:1.5 instead of a 1:1/8  (3:2x12 = 3:24 = 1: 8) ratio?
was doing some experiements with this mazzilli, and with a coil of high inductance driving a coil of low inductance, it forms a very solid square wave .... so the total time of drive on the output is actually very short (changing input current results in output current) so although it may be high current, it's only higher for a short amount of time?  When I reverse the coil so there's a low inductance driving a high inductance, then I maintain smooth curves....
T-1000
If you spending much time of reassembling nanosecond pulse generator my suggestion would be to use one itsu already had.
The requirement there is very sharp pulse of range 1kV+.
The alternative way is to use shotgun approach with spark small gap for catching effect. Later that can be switched to nanopulse generator.
The coils are Kapanadze style just Ruslan has primary frequency of 27kHz instead of 50Hz.
http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=216#224549
"Эффект с катушкой Капанадзе у меня оболденный. "
http://realstrannik.ru/media/kunena/attachments/630/aquarium-1.gif
http://realstrannik.ru/media/kunena/attachments/630/aquarium-2.png
The inductor is on the side winded to opposite way than beginning of longest output bifilar and the frequency is 1/3th resonant frequency (3rd harmonics) in phase lock:
http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=180#224323
"(3-я гармоника) Естественно всё это должно быть в фазе. Тогда будет эффект ! Накачка работает например на частоте 27 кГц. "
P.S> Wonder if itsu is watching this thread as he could already try reuse nanosecond pulse generator here...
Cheers!
MenofFather
I think most inportant not 1 Kv pulse. But HIGHT frenquency. Itsu get frenquency about 1-5 kiloherc. Ruslan use frenquency about 530 kiloherc. So, I think, need made nanosecond pulse generator, maybe not 1 KV, but 600-700 volts and frenquency 300-500 kiloherc. But did you see, that Ruslan use big ferite ring in nanopulser generator? Itsu and Dally use small ring. So I suggest, small ring can not give hight frenquency, because it imideatly makes hot. I try with ferite ring biger than in Dally and Itsu, but smaller than Ruslan and it with frenquency 250 kiloherc and power consumption about 7-10 wats, wery fast makes hot (I for pumping use mosfet IRF630, you know with two small bipolar transitors for it fast closing and opening).
