0 Members and 894 Guests are viewing this topic.
NickZ
  Thanks for your comments guys.
   T-1000: I tried to incorporate your recommendations of turning on one part of the circuit, then the other part. I have three parts going.
First, I turn on the HV pulses from the ferrite cored Joule Ringer to the yokes secondary output coil, then the main Mazilli crt is turned on, which charges the feed back cap (instantly). And, which is also connected back to the input side.
I've already tried it the other way around, but, see no advantage, one way or the other.  Obviously, I don't have my resonances in sinc, yet.
  The one thing that does seam to be working is the feed back circuit which is not heating up at all now, and does help to light the incandescents a bit brighter as well.
This loop is also connect and lighting the 18w 24dc bulb, (burnt out a 12 bulb). I've also tried connecting the feed back loop up separately, after the main oscillator is running, then disconnecting the battery source, but, still no cigar.
Waiting for the zeners to arrive next week (I hope), to be able to remove the Dc bulb, and connect the feed back loop direct to the input, for full effect. Can't wait...
d3x0r
@TinselKoala
Any hints what might be causing these spikes?  Scope probes are across the capacitor on my mazzilli oscillator thing...
Diodes are now MBR1100 http://www.onsemi.com/pub_link/Collateral/MBR1100-D.PDF  ( 10V/ns dv/dt recovery)
Maybe I should see what the choke coil is doing...
TEKTRON
Quote from: NickZ on June 29, 2014, 10:48:15 AM
Nick, Mailed this am. They said about 6 days. Any faster, was cost prohibitive.
00
Quote from: MenofFather on June 28, 2014, 03:06:36 PM
https://archive.org/details/MVI2464
My try mix kacher frenquency with low frenquency to get overunity. But unsucsesfully. Maybe I something wrong do.
4 requirements for ou
1. hf oscillator(AC)= kacher(first generator)
2. spark (electrostatics+magnetics) hf dc dioded kacher can be used(2nd generator)
3. output coil design must be cw+ccw
4. ferrite rings or ferrite rod bundle core
00
