0 Members and 161 Guests are viewing this topic.
00
Quote from: MenofFather on June 28, 2014, 03:06:36 PM
https://archive.org/details/MVI2464
My try mix kacher frenquency with low frenquency to get overunity. But unsucsesfully. Maybe I something wrong do.
4 requirements for ou
1. hf oscillator(AC)= kacher(first generator)
2. spark (electrostatics+magnetics) hf dc dioded kacher can be used(2nd generator) those who want to avoid spark can feed  the hf dc to coaxial cable shorted at other end
3. output coil design must be cw+ccw
4. ferrite rings or ferrite rod bundle core
00
Quote from: d3x0r on June 30, 2014, 04:35:12 PM
@TinselKoala
Any hints what might be causing these spikes?  Scope probes are across the capacitor on my mazzilli oscillator thing...
Diodes are now MBR1100 http://www.onsemi.com/pub_link/Collateral/MBR1100-D.PDF  ( 10V/ns dv/dt recovery)
Maybe I should see what the choke coil is doing...
Ah, you have discovered the Viking Warrior waveform! Looks pretty cool.
I'm sorry but I've lost track of the exact circuit you are using. Can you please post it again, including component values and probe positions? And also the scope settings, I can't quite make them out in the photograph.
Quote from: Acca on June 28, 2014, 04:06:31 PM
Here are the latest posts by Ruslan..
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Frealstrannik.ru%2Fforum%2F39-kapanadze%2F134930-ustanovka-ruslana-kulabuxova.html%3Fstart%3D216&edit-text=&act=url
off topic below ....
Ruslan in his element...DJ'ing mixing...
http://www.youtube.com/watch?v=6Ku4WVKGB8g
TopRadio in Latvia Riga...office
http://www.youtube.com/watch?v=S_FsVgVFTrA
TopRadio transmitter sight..
http://www.youtube.com/watch?v=5DRvW_1miC4
Acca..[/font]
That last one is not off topic at all, and in fact is probably the most significant of all the various Akula/Ruslan/Kapanadze/Dally etc. videos we have been shown. The question you really should be asking, and experimenting with, is this: Can any of these _tuned circuits_ act as receivers of a really really powerful RF signal at around 90 MHz, or sidebands/multiples/subharmonics of same, particularly when in the near field of the antenna-transmitter structure?
d3x0r
Quote from: TinselKoala on June 30, 2014, 07:44:54 PM
Yellow and green dots indicate where the scope is.
Scope settings at 1V/1V  10uS  probes set at x10/x10.
Input voltage around 12V.
Choke; is about 10mH
Coils are about 908uH (0.9mH)
Coil that is not connected is about 6mH
Resistor to ground is 10k  (9.8k measured)
resistor to power is 470
C1 is 500nF I think
M1/M2 IRFP4020H
Added another shot side by side with gate signal ; second scope 200mV/200mV  10uS; probes set at x10... But you can't see division lines...
Think slightly higher voltage on the second shot
Edit; added scope (blue is on the choke before the coils, Yellow is on one mosfet base)
d3x0r
Quote from: TinselKoala on June 30, 2014, 08:55:54 PM
That's a good question; Last post Ruslan says Kacher IS tuned to 1.2Mhz...
