0 Members and 203 Guests are viewing this topic.
T-1000
Quote from: 00 on June 30, 2014, 06:42:45 PM
4 requirements for ou
1. hf oscillator(AC)= kacher(first generator)
2. spark (electrostatics+magnetics) hf dc dioded kacher can be used(2nd generator)
3. output coil design must be cw+ccw
4. ferrite rings or ferrite rod bundle core
00
I will add my own thoughts then:
1) You must have cw+ccw "sandwich" on output where each part are half length of previous. So individual coil pairs won't give inductance while net connections on "sandwich" will introduce it. The way around Lenz law is there ^^
2) The inductor should resonate on half wave of output summary coil (calculate by sum of wire length of secondary coils). The winding is on side (kapanadze) or on first layer of output coil (Ruslan/akula)
3) Under inductor coil you should have coaxial cable coil or similar for making scalar wave spikes of 1/4th resonant frequency for output "sandwitch" bifilars. The repeating cycle should be 1 pulse on each top of sinewave in inductor...
So this is something to test and find out on behavior, should not take too much time... :)
NickZ
   There are some (many) things that I don't understand.
   First:
   "spark (electrostatics+magnetics) hf dc dioded kacher can be used(2nd generator)
3. output coil design must be cw+ccw"
   What diode is to be used for the HV pulcer circuit, to rectify the AC to DC. Is this half wave DC, or full wave?  What voltage/current is this rectified Dc providing?  Just how and where is it (this rectified DC) connected to the main oscillator crt coils?
   I understand the "sandwich" wound coils, but what are the exact turn counts on Akula's second video device's PVC tube output coil? Are those coils also sandwiched, or not?
As well as the wire gauge used.
Also, what are the Kachers turn counts on the PVC tube air coils.
  It is easier for me to understand the idea of a primary and secondary coils, as used in the Akula yoke core. The three turns coil on that same yoke is the third coil, as well as being a second output coil. Probably used to down step the voltage and up the current of the low 30 to 60B (volt) output to the in series capacitor of unknown value. What is the value of this in series cap? Telling me the needed frequency of the capacitor does not help, as I am not able to read frequencies, at this time.
  But, the main question is: can't we just use a commercial mosfet driver circuit with adjustable duty cycle and frequency controls, for the main oscillator crt. As well as one for the HV pulces circuit. IF not, why not.  Or are these REALLY needed, at all???
As I still doubt that Tariel used anything like that for his 5 kw device.  Or, that he actually built and made any of his shown devices. So, who really, are the guys with the brains...?
  Also, why has not one of these FE devices been connected to a load and run 24/7.
This leads me to believe that none of these circuits are actually fully functional...Yet.
T-1000
Quote from: NickZ on July 01, 2014, 01:58:35 PM
http://realstrannik.ru/media/kunena/attachments/630/aquarium-1.gif
The capacitor in series resonance make maximum magnetic field on primary coil. This function is easy to guess.
What I heard about Ruslan's FE generator usage from trusted source is opposite... ;)
NickZ
  "The capacitor in series resonance make maximum magnetic field on primary coil. This function is easy to guess."
   Guessing is something that I'm trying to avoid. Does anyone know the actual current/voltage ratings of the in series AC run cap of the Akula 1150- 1500 watt crt. As I can't afford to buy a bunch of different relatively expensive run caps, to see which one works best.  What would this cap be if using only 12v input source and a 120v output. Using a 12v battery, not an input source of 24v. Would it be the same value cap, or not?
   So, the current thoughts are that the Akula second device, is using the exact same windings scheme as the aquarium device?  What is the wire gauge.
If so, who has confirmed this to be the case. Did they actually count the windings on the AKULA device, or not. How do we know this is true.
  The first Akula device did not use the same core windings design, at all.
  "What I heard about Ruslan's FE generator usage from trusted source is opposite..."
  Meaning what? That Ruslan has a device running a load 24/7, but will not show it???
Right! Maybe ask the trusted source to confirm this, as there have been NO devices shown running permanently.
T-1000
@NickZ
Well, not everyone will advertise and even come to public showing FE generators, most of them prefer to stay out of sight when it comes to practical applications for good reason. Simple example - the town with Testatica and how it ended there. If you have equipment far away from mains power lines those locations are perfect to apply FE generators for powering equipment.
Also for series resonance - if your secondary coil does not affect primary coil, how you can transfer lots of power then? If primary coil consumes miliwatts and you attach it directly, there will be miliwatts on the output too. So the series resonance is perfect way to raise amps on primary coil. In addition if you disrupt the magnetic field on its peak with another field (scalar in akula/Ruslan case at least) how do you think the output coils will react to that? I would not want to go guessing all around this, it is better just to try what I already said.
Cheers!
