0 Members and 912 Guests are viewing this topic.
zcsaba77
Quote from: T-1000 on July 01, 2014, 02:22:16 PM
http://realstrannik.ru/media/kunena/attachments/630/aquarium-1.gifThe capacitor in series resonance make maximum magnetic field on primary coil. This function is easy to guess.What I heard about Ruslan's FE generator usage from trusted source is opposite... ;)
Hi for all
If i good understood winding goes like that:
1. 48turns ccw
2. 48turns cw
3. 24turns cw
4. 24turns ccw
5. 12turns cw
6. 12turns ccw
All with one wire: 6mm2
Is it single or multi tread? And its good order with winding? And possible continue this doubling (halfing) effect (put to begin 96+96 or 6+6 to end)?
Regards zcsaba77
T-1000
Quote from: zcsaba77 on July 01, 2014, 05:10:46 PM
Hi for all
1. 48turns ccw
2. 48turns cw
3. 24turns cw
4. 24turns ccw
5. 12turns cw
6. 12turns ccw
Regards zcsaba77
To be more clear:
1st) layer  48 cw + 48 ccw
2nd) 24 cw + 24 ccw on edge of 1st pair
3rd) 12 cw + 12 ccw on edge if 2nd pair
All these pairs are connected in series.
zcsaba77
Quote from: T-1000 on July 01, 2014, 05:26:52 PM
To be more clear:
I see just does turns forth and back, that is prefered single or multi tread wire? But its not clear all used lenght example 1unit, primary coil wire lenght must be 1/4unit? Or just resonance must be 1/4, wires lenghts not important?
T-1000
The concept I collected from pieces is to resonate this output sandwitch on half wave from primary and quarter wave single pulse length from nanosecond pulse gen on peaks of primary sinus wave. Also the primary should be in series resonance.
NickZ
    T-1000:
    Yes,   I understand.
   "The concept I collected from pieces is to resonate this output sandwitch on half wave from primary and quarter wave single pulse length from nanosecond pulse gen on peaks of primary sinus wave. Also the primary should be in series resonance."
    Thanks, I appreciate that information.
    But, We need exactly details, to get somewhere with this.
    YOU can e-mail me, if that would help us out. PM me and I'll give you my e-mail address, etz.
   As you know, I use NO test instruments, at all.  So, keep that in mind.
   I empathize with the real FE inventors, and their ongoing fears of the unknown consequences in supplying the secret information.
  I've seen the interrelation of the three different circuits that I now have running and all working together. The Mazilli/yoke crt, the HV pulse crt, and the feed-back loop, are all running together, to heterodyne the running frequencies. The yoke rings, chartters, vibrates, and at times especially when holding the magnetite magnets onto the ferrite yoke to tune it, I can feel it's frustration, vibrating like its going to explode. Then,  all is quite, the different frequencies aline, the ringing almost stops, and the bulbs brighten up.  A couple of times I've run past the sweet stop(s), and seen the light. I know that it's possible. Just need to work on it. And to also use the right tuning and holding caps, the special type of copper wire (no oxygen), the proper zeners. And a little magic.... Well, a lot of magic...
