0 Members and 975 Guests are viewing this topic.
Acca
Here are the latest post by Rusaln Kulabuhov aka.. "TOPRUSLAN" on the russian forum ( link provided below )... Looks like he is helping experimentors, however he is very  "touchy" about his discovery and has very soft "feelings".. The best way is to be nice to him and make him feel wanted, which is very good as it looks like he really wants to make a big difference in the world, which is
"helping out the world"..
Wow that is profound !!
Acca....
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Frealstrannik.ru%2Fforum%2F39-kapanadze%2F134930-ustanovka-ruslana-kulabuxova.html%3Fstart%3D216&edit-text=&act=url
d3x0r
d3x0r
Quote from: Acca on July 01, 2014, 09:06:42 PM
Ya, right.  That's why he says Wesley 'stole' his videos, and why he's deleted his youtube channel?  He has interest only in himself "helping the world".  I dunno he briefly had 2 videos with scope shots that indicated 73Khz and 27Khz; no idea what it was connected to.  I tried to grab them at the time, but missed the second one... And then he said kacher is tuned to 1.5Mhz; which I guess might be possible, Mine's 633 at 200 + a few turns, but I think my tube is slightly larger... not sure it's 50% larger...  Tried a few different transistors and they are basically all equivalent at that... hmm maybe it does go up to that much frequency if the variable inductor and top load isn't connected...
@T-1000
Any suggestions on a good technique for measuring resonance of layered coil?  I mean it's induction without much capacitance... (ie a inductive bulb isn't a capacitor, so it's not very resonancy?)
NickZ
  I think that it would be best to separate the Akula device, from the Ruslan one. As we are mixing potatoes with pears.
  Maybe the best core to replicate is the aquarium set up, or maybe not. The different winding methods are not the same, some guys are saying it's one way, while other guys are thinking it's the other way. But, ultimately they may still work similarly, if the windings count is the same. Who knows, if no one is working to test the different winding methods.
   d3x0r:  The makes and types of bulbs used, their wattage ratings, and the number of bulbs used are all a functioning part of the circuit, and are not just simply the load. Therefore they are very important part to obtaining the best operational frequency.
  If I just remove one of the 5 or 6 100watt bulbs, my systems output can drop by almost 1/3 or so of what the previous lumin level was, instead of going up, like would be logical.
  The same can result by just removing a single tuning capacitor. My yokes primary coil tuning caps run from 0.22uf to 0.47uf, with the higher voltage ones like from 400v to 1600v working best, without any heating issues. But, that same value caps does not always work as well on the yoke's secondary coil, (output side). And like T-1000 mentioned, may need to be in series, instead of parallel.  Also, if I change or add another coil(s), along with the yoke core, the same tuning set up may not work as it did previously. So, your crt may need different caps, etz...
   But, do keep trying to use the Tv yoke, as it seams to have a highest output over any other core that I've tried, so far. Yours looks the same, as mine, at least by it looks and size of it.
  As I don't have any test gear, I just add bulbs, caps, diodes, transistors, etz... and see which ones, or which combinations of components make the bulbs light up brighter.
Not a very high tech way of doing it, I know,  but it works for me. And will work for anyone that does not have the means of buying, borrowing, or obtaining the scopes, meters, etz...
        NickZ
MasterPlaster
If I had a Russian TV yoke may be I would get involved but as they are so rare I just keep looking!
