0 Members and 136 Guests are viewing this topic.
zcsaba77
Quote from: T-1000 on July 01, 2014, 05:52:27 PM
The concept I collected from pieces is to resonate this output sandwitch on half wave from primary and quarter wave single pulse length from nanosecond pulse gen on peaks of primary sinus wave. Also the primary should be in series resonance.
look like that:
Output 1unit frequency
Primary 2units frequency
Nanopulser 4units frequency (or 1/4 unit?)
And peaks must be triggering on top sinus wave (or little bit delayed after?) on primary,
primary is look like ruslans/dalys coax end shorted coil?
T-1000
Quote from: d3x0r on July 01, 2014, 10:15:19 PM
@T-1000
Any suggestions on a good technique for measuring resonance of layered coil?  I mean it's induction without much capacitance... (ie a inductive bulb isn't a capacitor, so it's not very resonancy?)
N. Tesla method - the resonant wavelength is by wire length. Also that needs to be multiplied by 0.75. Just not sure if that can be applied to cw+ccw pairs, need real assembly of coils 1st..
Quote from: zcsaba77 on July 02, 2014, 02:12:53 AMlook like that:Output 1unit frequencyPrimary 2units frequencyNanopulser 4units frequency (or 1/4 unit?)And peaks must be triggering on top sinus wave (or little bit delayed after?) on primary,primary is look like ruslans/dalys coax end shorted coil?
http://realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=288#225696
Quote from: topruslan on June 30, 2014, 10:05:00 PM
Шаг номер 1 - Намотать правильно катушку ! Индуктор 1/4 катушки съёма. Качер надо настроить на частоту 1,5 МГц , сделать Пуш-Пул генератор с развязкой через феррит от отклоняющей системы. Можно и другой. Всё чщательно зафиксировать и заблокировать конденсаторами проникновение по проводам ВЧ в генератор (микросхемы)
Найти все нужные элементы. Там где блок АПЧ - это обычный генератор с АПЧ постройкой резонанся. Но тут надо не забывать и о токе+напряжение. На ВЧ качере они отстают .
So here is update - the inductor length should be 1/4th of output coils length (as I suspected because half wave did not sound very right to me as per N. Tesla notes)... Also Ruslan tried to copycat Roman's(akula) version with Tesla coil (and mentioned 1,5MHz frequency on it) and push-pull has to be separated over ferrite yoke transformer (so close to akula's design) to filter out high frequency. And also he mentioned here about automatic frequency control for keeping in resonance.
Also the previously posted scope shot shows where nanosecond pulse is.. right on top of sinewaves.
magpwr
Quote from: T-1000 on July 02, 2014, 09:19:03 AM
http://realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=288#225696So here is update - the inductor length should be 1/4th of output coils length (as I suspected because half wave did not sound very right to me as per N. Tesla notes)... Also Ruslan tried to copycat Roman's(akula) version with Tesla coil (and mentioned 1,5MHz frequency on it) and push-pull has to be separated over ferrite yoke transformer (so close to akula's design) to filter out high frequency. And also he mentioned here about automatic frequency control for keeping in resonance.
hi T-1000,
Wire length used to achieve 1/4 wave during Tesla time is actually meant for his "pancake coil" only and not to be mixed up with modern day coil as eg: wound around pvc pipe or resembling a B&W coil.
I don't think Tesla coil (few hunderd turns )resonance would be around 1.5mhz.It's likely the kacher frequency which i am curious on how to derive one or tune.
And tesla coil tune to run at 1/4 of 1.5mhz at 375khz.Ok this part i am just guessing to try to come up with any possible answer/theory. :D
T-1000
Quote from: magpwr on July 02, 2014, 12:21:20 PM
hi T-1000,
Well, in the way I was tuning circuits was to that rule from other end - 1/4th resonant frequency on inductor instead... ;)
zcsaba77
So wire length difference is clear 1:4 (primary:output), and nanopulser coil must be keep wire difference keep too? or just enough keep frequency on depend primary, trigger peaks pulse like you mentioned (shown) before? Previously asked but not was answered, all coils wire is single or multi tread? because I heard from somewhere HF prefer multi tread like induction cooker coil, but sometimes cant flow HF just on single tread!
