0 Members and 40 Guests are viewing this topic.
Hoppy
Quote from: magpwr on July 07, 2014, 07:56:56 AM
hi Hoppy,
If the primary coil behaved like a intended "functioning induction coil" using below 10Amp from 12volts battery which we would then easily verify the estimated"power of the "coil performance" merely by placing metal eg:screw-driver into it which would then allow us to easily verify and find out the root cause of the problem rather than completing the secondary coil then get lost/confused if there is no required output.
If a typical step-down or step-up transformer is "under powered at the primary" the output coil/outcome would reflect the same.
For Nickz yoke experiment the output is now routed to the 5x100watt bulbs which itself already revealed an interesting effect even if i compute at conservative output 1/2 of 500watt output brightness.
It would be estimate 250watt of output power take that and divide by 12volts =20Amp at least for battery to deliver that amount of Amps.
I am just thinking if he apply proper L/C resonance and routed output to induction coil\primary coil for the those layered coil which may reveal another interesting result.
Long story short-What i am trying to say if we don't get useful output from yoke core for the 1st stage to supply power then don't bother aiming for the 2nd stage -layered coils(kapanadze coil  :D ).
Thanks for your explanation.
Although Nick is currently unable to measure his setup in terms of power consumption, it is highly unlikely that anywhere approaching 250 Watts is being consumed by the lamp load, whilst powered from his small and battered old SLA battery. Unfortunately there are still some people attempting to estimate power levels from looking at bulb brightness in videos.
GeoFusion
Hi there  :), has been a while.
Wanted to check how things are on the forum.
Alot of progress lately and succeeded. but Alot of changes to my experiments and replications.
For everyone that is working with Akula devices or trying to replicate Ruslan devices,
The most important part most of you are missing out in implementing is " ~Impulse ~" within.
Think about how a basic SG tesla coil works.. ;)
Happy to see you guyz are still on the forum.
Cheerz~
Hoppy
Quote from: GeoFusion on July 07, 2014, 01:51:19 PM
Hi there  :) , has been a while.
Cheerz~
Nice to see you back Geo. Hope you've got your shoes on now with all that HV flashing about from those impulses.  ;)
GeoFusion
Quote from: Hoppy on July 07, 2014, 02:05:29 PM
Hoppy:
Nice to hear from you Hoppy, Thanks.
;D Safety is always a first. But it's always great to know where danger lies and where it's safe.
To everyone that is willing to read:
In any case," Impulse in circuits is the key of concentration and to reach resonance with it "  not HV HF Oscillations
( As my old experiments such as the RMG ), look at the schematics of Akula and Ruslan.
Impulse is like a beating heart inside of you generating heat in your chest that your Soul's vibrational energy creates,
Alternators use Impulse, Tesla coils is impulse, Even Kapanadze mentioned that Impulse is needed in his time and even Tesla. :)
Core of the planet has and impulse and even the sun to maintain the field and vibration.
So you can all see where this is getting to guyz.
A very fine Tip to all of this,
When you see a Inverter work, that makes 12Vdc from car battery to 120Vac or 220Vac 50/60hz,  have you ever wondered why to voltage never really dropped when measuring? because of Impulse (=.
Cheerz~
T-1000
Hi GeoFusion, nice to see you're back :)
Hopefully it was busy time for you with making OU machines which you could share with community...
Talking about impulse I agree with GeoFusion in one moment - when the disruptive pulse shocks already magnetized coil to the maximum on different angle like needle cutting magnetic field in half on 90 degrees. Think how much energy that releases in a moment of the microseconds...
Also there is quote from Ruslan in http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=324#227011 :
Quote from: topruslan on July 07, 2014, 06:00:00 AM
Я процесс понимаю так,как понимал его и Никола Тесла и многие другие спецы этой области.
Тут всё очень просто, это "Пружина" :huh: А генераторы работают над её сжатием и освобождением.
Т.е. Импульс ВЧ должен обладать правильной силой и фазой :unsure:
Сбалансирован по времени и по силе с накачкой (Генератором создающим эту пружину) Помните мои фразы про осцеллограф в видео?(я там конечно грубо рассказывал,достали просто)
Именно на осцеллографе всё будет видно :whistle:
Не забывайте про ВЧ !!! При его появлении тормозится ток :huh: Вот этот эффект мы и используем для отпускания "пружины" которая вылетит в катушке как сильнейшее магнитное поле :woohoo:
Попробуте сжать пружину,а потом резко отпустить (дать ей выскользнуть) Ух какая энергия высвобождается :ohmy:
Святолуг вот не знает ,о какой пружине я говорю... А я рассказываю про свободные колебания :whistle:
Если вы поняли что я написал,то поймёте как электронным путём это всё преобразовать :blush:
Это сложно только кажется. Но по этапно собирая всё красиво и качественно,а главное правильно. Вы получите результат прироста КПД,а там и самозапит :unsure:
Translation:
I understand the process in full like Nicola Tesla and other specialists understood.
It is very simple, just the "Spring" (comment: mechanical analogy) :huh: And generators are working with making its tension and release.
So HF impulse must match by time and phase :unsure:
After making balance by time and power with exciter (the generator which is making that spring) Remember my comments with the scope shots in video? (I just was a bit rude talking there as everyone got me to that)
So you will just see everything on the scope :whistle:
Do not forget about HF !!! When high frequency appears there is slow down of current :huh: So we are and using this effect for "spring" release which will jump off in coil like strongest magnetic field :woohoo:
Try to make tension on spring then instantly release (let it jump) So much energy is being released :ohmy:
Svatolug just does not know on which spring I am talking about... And I am talking about free oscillations :whistle:
If you understood what I just wrote so you will understand how to transform this in electronic way :blush:
It only looks complicated. But when step by step you will assemble everything looking good and with quality and in truly way you will get result of power efficiency gaining and there is self powering :unsure:
