0 Members and 63 Guests are viewing this topic.
GeoFusion
   Grum:
Hi there :), join in the adventure hehe.
Thnx for sharing your video once more :).
and no, the device is a bit different than what you have tried replicating, what I admire is that you tried it out yet it worked so beautifully.
But the lower part on the schematic of the circuitry I posted can be used for that particular device too.
A TV ferrite yoke is essential here, In my case.
nicee :) that is alot of voltage charge there.
Yes using the circuit as a induction heater :P have done that and does massive heating, oh yes things get hot very fast :)!
auch  :( that is sad, blew the IGBT's that way, you need a Overvoltage protection and Snubber on the Fets and IGBTs for protection! :)
The circuit I use can also be used used as a SSTC driver too.
Check the post if you haven't :) , Full drawing of it and the impulse circuits.
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/4635/#.U8BwzfnYVp4
Take a look at this guy, He is somehow using almost the same circuit that could be possibly producing Squar waves using mosfets what akula used.
1:
https://www.youtube.com/watch?v=IsQObrVcgwI
2:
https://www.youtube.com/watch?v=iuKTXc_vvT0
Cheerz
NickZ
  Geo:
   Ok I'll put a thinner gauge primary wire on the Exciter, I'm still adding more coil turns on the induction heater side, and testing it now. I want to see just what the thicker red wire does on the Exciter first. As I've used this exciter's output coil before, I know what to expect from it. But, I want to use the thicker wire to see what it does. As I feel that even flattend copper tube, would work best. Or not?
  I just found my 3 inch ferrite rod, to make the HV choke with, that was what I needed to continue, for joining the two separate coils sides together.
  I think that in time we'll find a way to just buy both the induction crt board, as well as the HV nano pulcer crt board, commercially made.
  But, having the exact coils specs, helps. I made the yoke primary all in the same direction. The picture was taken previous to that change. But, I see no difference, in the output readings, one way or the other. Nor with the yoke clips on, or off.
I am still using the tape between the yoke core halves.
   Thanks for the tips.
magpwr
Quote from: Acca on July 11, 2014, 04:22:08 PM
Ruslan generator new clip...
https://www.youtube.com/watch?v=tT9m6F53atk
schematic of  the coil...from  russian forum
http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=342
from youtube "leader jane" channel  who is making the Rusaln coil also..
https://www.youtube.com/watch?v=anvb_PXG1YA
https://www.youtube.com/watch?v=yKjgMmZcFA0
and Thanks  !!!     "Geo"
Acca...
hi Acca,
Thanks for posting the video.This video produce even better result than the spark gap in a Russian video which i have seen sometime back which power a Sand Grinder at slow speed.
This is my findings base on the 2 above video(Provided if you understand LC resonance)-
113khz as measured at one of primary 6 turns input.
"Since we know the value of the 250volts A/C capacitors at primary coil is 2.2uf/2= 1.1uf (In series)
Mazilli circuit is using "100ohms"  3watt resistors as pull up.I am merely suspecting his is using IGBT's which already function well at 18...20volts.
Applying LC formula we will able to find out the "inductance" for one of 6 turns primary as well.
40khz as measured at secondary coil output
131uH or 0.131mH Secondary coil inductance value
Base on video Value entered into online L/C calculator
Frequency 40khz (Secondary output)
Inductance of secondary coil 131uH
To derive "120nf" for capacitor value to use(Used 4 high voltage capacitor connected in parallel to achieve around 120nf)
From the capacitors bank output it is connected to Full-Bridge rectifier (4 diodes).
Full-Bridge will produce ripple 2 x the input frequency.
The interesting part of the video the power is provided by 24volts 2 Amp =48watt  from adapter and still manage to power a drill at below 100% speed.
Question is i pose even a 85% pure sine-wave 220volts inverter can't do this at 2amp 24volts battery input. :D :D :D
Maybe lasersaber is able to show to the world using solar 2..3 Amp to power even more useful devices under the Sun.
I am merely thinking HHO to indirectly power vehicle under the Sun using this output voltage.
For everyone else-
"You can't go far without frequency measuring equipment and L/C meter"
Utopia Now
Wow Ruslan  Wow,  Wesley  Wonderful   News,
Wonderful team  work , Wonderful how  you  are all doing very important work, very inspiring work .
Many people on this Earth are  and will be Grateful for what is happening Now  :)
          http://www.youtube.com/watch?v=F7kOKI7QLVw
Also many thanks to Akula and Igor and  all the  others  with the Heart on the right place    Yeahhh !!
Of course i am very enthousiast  to see more details or a specific schematic,
I am allready studying the other parts ( 1 to 6 ) from Wesley News.
The  more we work together , the better we can CoCreate ,   the  happier we will all be .
Co Creating people Happy Wonderful people  :)
Lovely friendly Greetings from here,
Utopia Now
