0 Members and 62 Guests are viewing this topic.
GeoFusion
Hi guyz ;D.
good day to you all.
   Nick:
Alright :), you could try anything but be careful, you might blow up some components,
but it could be also the case that it could work so it's all experimental.
Yeah, you could try the flattened copper tubing too.
But mines is a 1.5mmsquar wire or 2.5mmsqaur for the kacher a like circuit.
Nick try to build the Schematic !, If you can and willing go for it, it's an opportunity that is givin here so anyone willing could replicate it.
Try to build the Sqaur wave induction Mosfet pulser. But be carefull if you do.
Yes the yoke needs the two gaps  insulated and  alright has been changed.
   Acca:
Welcome aboard the journey, :)
Thank for the videos and pictures are super interesting and new video of Ruslan and his device :).
you can see now he is powering If i'm right 2.3kw of power in total with it.
I also have that particular schematic too.
But the schematic is a bit more complicated with the Nanosecond pulser circuit. The circuit is being fed 150Vdc+ to pulse from a Coaxial cable inside.
Great video of leader jane channel, he also has a nanosecond impulse system there with Fets or IGBT's.
as you can see the power is great! and :).
magpwr:
thank you for the specs and pic and Vidoes provided on  LC resonance :). In the video the guy is using a nanosecond generator pulser which is what we need to work on to and who is willing to work on it.
Yes you will need some measuring equipments to move forward in development of these devices but You could without but only than it's pure luck making it work too. :)
   Wesley:
Thank you for the translations once again, really helps :)!
   to all:
We work together to share and point out to what we should be focusing on, :)
One consciousness, work together as the ppl of planet earth.
Take time to study the Schematics I posted, I will provide small ones soon.
Cheerz~
Hoppy
Quote from: magpwr on July 11, 2014, 11:32:12 PM
hi Acca,
Thanks for posting the video.This video produce even better result than the spark gap in a Russian video which i have seen sometime back which power a Sand Grinder at slow speed.
https://www.youtube.com/watch?v=anvb_PXG1YA
https://www.youtube.com/watch?v=yKjgMmZcFA0
The second part of the video shows clearly what can be expected from tuning to resonance using a straightforward step-up transformer arrangement driven from a Mazilli oscillator. The max input power level is around 48W, so taking losses into consideration, the lamp load is likely to be consuming around 10W - 20W. This simple setup is a good starting point for taking measurements and experimenting with various LC arrangements with suitable measuring instruments - LC meter and scope.
Hoppy
Hi Geo,
Thanks for posting the various schematics. When will you be ready to show us the video of your self-runner?
Jeg
Quote from: GeoFusion on July 11, 2014, 02:02:08 PM
   Jeg:
No problem man :). this is the whole Generator circuit. But anyone can modify it, but It will be harder to Tune if you do.
The circuitry produces the High frequency and squar wave pulses for  the system to operate.
If you build it as you see on the schematic you will see.
Cheerz~
Thanks man, u are really very helpful. Just few questions If you don't mind.
1. At your circuit, the 2.2nf capacitor at the output resonates with the inductance of the 8 turns half primary? Here you make the 190khz for your Tesla secondary?
2. What is your chock inductance?
Looking forward for a quick drawing of your output coils arrangement.
NickZ
   Geo:
   Ok, I'm confused. Are you suggesting that the HV pulser coils, and it's driver circuit are not totally essential, nor is hererodyning along with the induction generator circuit part. As a SELF RUNNER, at least to some degree.   A simple yes, or no would help.
   I would be into building up the fairly simple circuit that you are suggesting. But, I still need to obtain the proper 18v zeners, which have not been delivered to me yet. They should be here soon.
  Is this the circuit (below) that you built? Just checking to be sure. As all these schematics being posted are all different. As well as the coil winding designs.
Akula winds his (air coils) output coil in the same direction. Only the air core primary is bifilar.  Or not?
