0 Members and 256 Guests are viewing this topic.
Hoppy
Quote from: GeoFusion on July 12, 2014, 04:04:49 PM
   Hoppy:
Yes, soon enough I will post some pics and videos as promised but it's best to investigate the circuit and understanding it. But I really don't want to be in the spot light just yet.
But I will slowly show parts that I use within the circuitry.
Btw, it does and can run without a battery,  this circuit setup and the entire device makes sense now why I couldn't get my older experiments to self feed , just as my RMG  circuit. it misses Radio frequency pulses, beating heart. A pulse.
:) it also has a ground connection too.
Geo,
??? You have already put yourself in the spotlight by claiming you have a self-runner. All you need to do now is demonstrate this with a video. Telling people that you first want them to understand the modus operandi of the schematics you have posted (which are not even your own designs), is an excuse IMO to further delay showing some visual evidence that your claim is genuine.  Akula starts a self-runner claim with a video, so why not you?? You appear to enjoy the attention from people feeding on tit-bits out of your hand.
PS. You clearly have not played Grand Theft Auto 2  ;)
stivep
magpwr
Quote from: stivep on July 13, 2014, 07:10:47 AM
How to tune circuit  with nanosecond  generator.
https://www.youtube.com/watch?v=wMPU_9yIlXI&feature=youtu.be
Wesley
hi stivep,
Thanks for the translation which assist to me alot.
To derive the inductance of each primary coil consisting of 6 turns.
Since we know each primary coil is being driven\switched at 113.9khz and value of ~250volt capacitor assuming as per capacitor label as seen in video it's is 2.2uf/2=1.1uf in series.
I merely use a simple online L/C calculator and key in random inductance value to derive a inductance value for each of the 6 turn primary once the output frequency as reflected base online calculator.
The value for 6 turns is 1.775uH to be exact but since base on my experience capacitor are never 100% tally with the written value there is usually +- 5% or 10% tolerance.
My previous experience with Mazilli -so mentioned as nanosecond generator the running frequency is base on L/C resonance for the primary portion.
The part which is completely new to me is the frequency as taken from the 80 turns secondary at 131uH is 40khz which should not\never tally with primary frequency 113.9khz base on video.
"This was definitely not taught during my time" :D :D :D
Base on simple calculation it's either 113.9khz/40khz=2.8475(div from primary frequency or
113.9khz from each primary coil x 2 =227.8khz(Since we know each coil from mosfet/IGBT drain is turn on at 113.9khz)
227.8khz/40khz=5.695(div from switching of both primary coil)
Base on video the only component which should be harder to get is the secondary capacitors 120nf/4=Estimate 30nf for each capacitor rated at around 750volts.
4 capacitor in parallel would have better advantage over a single capacitor of the right value since the internal resistance of the capacitor(ESR) is lowered by combining 4 capacitors together.
Not forgetting 4 HV fast response diodes is  connected as full-bridge rectifier from bank of capacitor which will produce ripple 2x the input frequency to drive the drill(optional but nice). ;) ;) ;)
For others-Completely forget about Akula device if you can't even solve this simple setup with required instruments and components.
It will be quicker for those with Mazilli circuit on hand to start experimenting.
I have just completed doing PCB designing for the China Don smith circuit yesterday.
4 circuit completed
1)Variable HV voltage capacitor supply-300 to 1600volts.Capacitor bank is able to be charged  to 1000volts in  2 seconds using 12volts after changing to "ultra high grade" $$$ insulated wire for secondary high voltage generator.Implemented simple soft-start on PWM I/C to prevent frying the HV transformer 18AWG primary coil for the last time.
Once capacitor charged up the circuit goes into standby/capacitor top up mode <0.4Amp.
2)Optical isolated IGBT driver reused back FOD3180 to switch the $$$  6x Cree IGBT's and redesign pcb circuit board.
3)Redesigned driver circuit for 3" toroid to supply power to all 6 opto IGBT driver via 78M20(20volts regulator).
4)Primary PWM  generator using I/C:3825 to vary frequency from 185khz...235khz and applied 3..5seconds delay for the soft-start to ensure 20volts for IGBT\High voltage capacitor is charged and ready before IGBT switching begin.
   Signal will be fed to 6 x FOD3180 input simultaneously via 6 x 1kohm resistor from single output of PWM I/C.
Finally got my etching stuff/UV light ~400nm to save time/transparency/30cm length photoresist FR2 large PCB board but i'm only left with a large photo frame or glass to overlay transparency printout onto pcb and optional critic acid(to dissolve in hot water once) to enhance the existing etching solution and prolong life of reused etching solution. :)
What i am trying to say-My hands\time are full with this project to be able to continue with another at the moment. :D :D :D
NickZ
   MenofFather:
   I have some questions concerning Geo's diagram, which you made some circles on, and some suggestions.
   First you circled the mosfet protection part of the circuit. Are you sure this protection is not needed, and have you tried it without that protection?
   Also the voltage regulator, Not needed, maybe if using 12v battery, only?
   The small choke, also not needed?
   Everything marked in orange colored circles is optional for the circuit to work?
Can you explain how do you know that?
                       Thanks,
                                     NickZ
MenofFather
"Are you sure this protection is not needed, and have you tried it without that protection? "
This protection I not say, that not needed, with it better looks. I tryed, work without any protectiions, only 5 K resistor you can put betwen gate and source, I use only that protection. Here is small voltage (24 volts) and if you nice use this circuit, then you not burn mosfets without any protection.  Mosfets burning from overheating and from seems colector- emiter brake or maybe gate brake. But zener diodes on gate for me not help from burning, so I not recomendate put it's in that place if you want not waste moneys and want see more simple circuit.
"Also the voltage regulator, Not needed, maybe if using 12v battery, only? "
Maybe.
" The small choke, also not needed? "
Choke is not nessary, you can use it but it not make any feeling shanges.
" Everything marked in orange colored circles is optional for the circuit to work?"
In orange and red is optional, circuit works and without it and with it, it is not criticcal parts. If you акуратно use this circuit, for you not need in general, that part, that is in red and baisicly not needed, that is in orange.
"Can you explain how do you know that?"
Because I many work with TL and others generators and burn about 100 mosfets and transistors.
