0 Members and 314 Guests are viewing this topic.
Dave45
Nick this is an easier circuit to lay out, mine is built like this with no problems.
I used irfp460's
Dave45
I built one on proto board but smoked it so the next one I breadboarded  ;D
Dave45
You guys should take the time and build consumption meters, really helps.
NickZ
  Although I've placed this link below before, more information is being added to it as time passes.
  http://www.rmcybernetics.com/projects/DIY_Devices/diy-induction-heater.htm
  rmcybernetics.com is also selling ready made high powered induction heater circuits, along with adjustable controls. Might be the way to go... these should be able to handle what we are trying to do with them.
Although Geo does not think that commercially made induction circuit will do. I don't agree, as these can provide 180 amp output with frequency and duty cycle controls.
  Guys, thanks for the suggestion. I will try to connect my car battery charger, (12v. 10 amps) to my Mazilli/yoke circuit, and will report back. It may be that my batteries just won't cut it any longer.
  But, what I'd really like to see, is someone running a similar induction circuit connected to the Tv yoke, as I have, and to let me know just how hot their fets get when drawing over 500 to 700 watt loads.
BTW: Magpwr, my heat-sinks do have holes, and fins on both sides, and I've placed two fans on them as well. They are not blocks of aluminum, only.
   As mentioned, I plan on changing my set up when the zeners arrive, or I'll have to try to obtain them elsewhere (not easy). I also plan to include the bigger heatsinks, fans, etz...
   As I'm only running tests on this circuit for a few seconds at a time now, so the fans are not needed, although I have used them several times previously, but to no avail, fets still getting way too hot.
   I suspect that Hoppy is right, and the old batteries are the problem here. Maybe the fets are not switching properly, etz...even though the battery voltage only drops by 1/2 volt or so, when running the circuit.
  This has been an ongoing problem for me from the day that I built this circuit, as well as my Joule Ringer circuit, which also has the same transistor heating problem, when running 60 watt plus incandescent bulbs.
x_name41
here my sequential variant of the x_name41 ZVS-oscillator :)
$ 1 5.0E-9 3.9121283998153213 50 5.0 50
r 416 416 416 464 0 22000.0
w 592 400 560 400 0
c 672 400 672 304 0 4.7000000000000005E-7 -50.011044416459285
w 576 432 560 432 0
w 672 304 768 304 2
w 768 304 768 320 0
w 768 384 768 400 0
w 672 400 768 400 1
w 576 432 576 496 0
w 576 496 320 496 0
v 320 400 320 320 0 0 40.0 3.7 0.0 0.0 0.5
w 320 400 320 496 0
r 320 224 320 320 0 0.1
w 320 224 384 224 0
w 384 224 416 224 0
t 512 416 560 416 0 1 0.5985110710656962 0.5985360585740224 1000.0
w 736 384 768 384 0
w 512 464 624 464 0
w 464 464 512 464 0
w 464 464 416 464 0
w 464 416 512 416 0
w 624 352 624 464 0
w 624 304 624 352 0
w 416 416 464 416 0
w 416 224 624 224 0
w 624 224 688 224 0
w 736 336 736 384 0
d 672 400 640 400 1 0.805904783
w 592 400 640 400 0
d 672 304 624 304 1 0.805904783
l 768 320 768 384 0 6.799999999999999E-6 0.1370705685779981
x 95 649 169 655 0 24 battery
x 313 649 471 655 0 24 inductor 6,8uH
x 550 646 722 652 0 24 capacitor 470nF
x 894 648 946 654 0 24 base
x 431 107 696 113 0 24 x_name41 ZVS oscillator
x 514 385 612 391 0 24 2SC3987
x 604 286 686 292 0 24 1N4007
x 641 436 723 442 0 24 1N4007
T 736 224 768 272 0 2.1999999999999998E-4 1.0 0.0016848985388366322 4.3452450357778227E-4 0.999
w 688 224 736 224 0
w 736 224 736 208 0
w 736 272 736 336 0
w 736 208 800 208 0
w 800 208 800 272 0
w 768 272 800 272 0
w 768 224 784 224 0
w 784 224 784 304 0
w 784 304 768 304 0
x 708 198 849 204 0 24 220uH choke
o 10 64 0 298 5.0 0.2 0 -1
o 10 64 0 297 2.5 0.4 0 -1
o 10 64 1 299 1.25 9.765625E-5 0 -1
o 30 64 0 298 80.0 12.8 1 -1
o 30 64 0 297 40.0 25.6 1 -1
o 30 64 1 291 640.0 9.765625E-5 1 -1
o 2 64 0 298 80.0 12.8 2 -1
o 2 64 0 297 40.0 25.6 2 -1
o 2 64 1 299 640.0 9.765625E-5 2 -1
o 20 64 0 298 1.25 7.8125E-4 3 -1
o 20 64 0 297 0.625 0.0015625 3 -1
