0 Members and 1125 Guests are viewing this topic.
Hoppy
Quote from: itsu on July 22, 2014, 11:43:04 AM
Still not sure what this special mode is introduced by, seems that the battery voltage sagging is not the cause, but we do see some
RF feedback/oscillations on the battery voltage in this special mode.
Video here:  https://www.youtube.com/watch?v=JsMmGEQCCpE&feature=youtu.be      (still uploading).
Hope it helps  :o ,  regards Itsu
Itsu,
Its strange you still get this 'special' mode as I never saw it at any voltage. One thing that might be worth trying is to increase the inductance of your choke to see if you can lose the effect.
Hoppy
Quote from: NickZ on July 22, 2014, 10:54:12 AM
    Hoppy and All.
   Thanks for the info on your previous circuit, showing the bulb drawing 20 amps.
   There seams to be some confusion, at least for me, as Wesley also mentioned that the video using the Mazilli crt to run a drill on DC, is a nano pulcer crt. Is this correct, or not?
  But, the main question is, is an adjustable controls nano pulser really necessary for a self runner, or not.
  Geo mentioned that there are devices that don't use or need a separate circuit for a HV pulcer, although he doesn't show that, and says that he is using one for his self runner.
  MenofFather has circled the parts of the circuit below that adjust the duty cycle, as well as the frequency controls. Same circuit that Akula is showing, as part of his circuit. So, if this is NOT a nano pulcer, why not?
   Itsu mentioned that he built one for the Daly replication. So, what's the difference?
Nick,
Confusion is something we all live with in this game!
Until Geo shows us his working self-runner, I would not take too much notice of his comments about the HV pulser.
NickZ
   Hoppy:
   Well, Bud, I'm not holding my breath...
   In any case, it does appear that both Akula and Ruslan are using adjustable  frequency controlled HV, along with the duty cycle controls. So, it would lead one to believe that that is the way to go.
  And the main theme is obtaining resonance throughout, and also by the superimposition of two or more different pulsed frequencies. Reducing duty cycle to minimum, would probably also help to reduce the extreme heating of the fets, at higher outputs, like 1000 to 2500 watts, or higher.  Even with heatsinks and fans.
  Itsu:  Thanks again for your help, making the last video, and your reply.
   If we were to have exact circuits, and coils, it would be easier to compare just what's goes on with one thing or another. Like the component heating, bulb lumin levels, output voltages and current reading, etz... But, we don't. Still I appreciate you taking the time and effort to follow through with what you've been doing, and the help given, so far.
  Burning up your fets, is the last thing that I had in mind. Ha!
  I noticed that you have ceramic resistors on your Mazilli. I suspect that they may also be one of the reasons your device output is different to mine, and why your fets don't heat up as much.  I don't have any on my circuit, because I think that they hogged up two much power. Plus the Mazilli schematic does not include them, either. But, I think the Igor does use those resistors in his home made induction circuits, though.
  Personally, I like to work with just Magnetic electricity, as I always get the living sh!t shocked out of me when working ferrite cores, and HV. And my several fried meters didn't like it too much, either.
   The frequency of the Akula second device HV pulser crt must be high, but with very low amps, and low duty cycle. I think. As he is not getting shocked by it, which I like.
TEKTRON
Quote from: NickZ on July 21, 2014, 11:49:36 AM
   I'm also still waiting for the delivery of the 18v zeners to arrive, to see if they will help, or not. I hope so.
Nick, I sent 2 more on the 18th with the address in Spanish exactly as you wrote it.
zcsaba77
Quote from: itsu on July 22, 2014, 11:37:08 AM
Its also not a nano pulser as it does not produce nano second pulses.
The TL494 can generate up till 300KHz pulses, which is something like 3uS, so far from being nS pulses.
Hi Itsu
http://pdf.datasheetcatalog.com/datasheet/on_semiconductor/TL494-D.PDF
just 200kHz (oscilator frequncy) is 500nS still out of nano range!
what was your ic type what hold nS range?
reply again NickZ question: realy need nano range? not enough fast micro range? Tesla have or havent nano pulser? (ex: He has something (FE?) in electric motor car small like suitcase and he run with like devil, the device probably produce 15-20kWs, question is he was ABLE build nanosecond generator in HIS AGE??? of course if story was true about his car)
regards zcsaba77
