0 Members and 1089 Guests are viewing this topic.
magpwr
Quote from: NickZ on July 25, 2014, 08:03:05 PM
  Thanks again Itsu.  Well, at least we are finding that the fets do get hot, and the battery has nothing to do with it. You know that just one of those 12v 7aH batteries is enough to start a car, several times over, a big car.   I have done that with mine, more than once.
  To get the bulbs bright, you'll need to rewind your yoke coils as I've suggested. Remember that the primary yoke coil winds should NOT go past the yoke halves, or splits, as Geo has also suggested.
   IF you try two 100 watt bulbs instead, you'll probably find that they will light up much brighter than two 60 watt bulbs will. Also try to place tuning caps in parallel, on the yoke secondary side, 0.22 to 0.47uf, 650 volts or higher, in order to tune for resonance.   You have not tuned to balanced resonance with this set up, yet.
IF you have magnets especially magnetite magnets, try them on the yoke to see what they do to the signal on the scope. That would be good to see.
  No I'm not trying to burn your fets, but keep a finger on them, as you go higher in output. You'll probably find that the fets will also need fans on them as well, good sized fans.
   EDIT:
   I just viewed this video, and thought that maybe some of you might find it interesting.
https://www.youtube.com/watch?v=zPFmhgehS6c
hi Nickz,
Thanks for posting this link of Akula nanosecond secret pulser.
This was the missing puzzle of Akula which i was hoping for which i have missed out.
Base on oscilloscope the frequency is running at close to 100khz.(This is the simple part) :)
The long straight line which you can't miss shooting downwards as seen in the scope represent the back emf at around 354volts.
Then there is delay of 250ns to 2ms depending on the type of bulb used the low watt version he was using around 250ns the high watt bulb was using 2ms delay.
I can see high voltage capacitors 2.2nf 2500volts or 2 x 2.2nf capacitor connected in series.
For nanosecond pulse i think transistor is able to do the job.
Do anyone else have any idea beside assembling a pwm generator to generate 100khz with 2ms delay between pulse(This is the easy part) and think about the coil winding/interfacing part.To emulate signal.
NickZ
  Itsu:
  I thought that Akula's video would fill some gaps...  Glad you liked it. It helps to watch all his videos in the sequence that they were made, in order to see his development towards the self runners. He is an amazing guy, no doubt.
  Our job now is to make the best replication (hopefully of his second device), maybe in our own way. And to tune for this sincronized resonant peak, that can blow our lights bulbs right out.
  Picture:
   Of my Akula yoke core connected to the Akula air coil resonator, and a Joule Ringer HV pulser, also, which is for now connected to the air cores output coil.
Only one 100 watt bulb is lit (top left), not any more for now on this pic below, but its pretty bright. I'm still tuning.
  Sorry for showing such a mess... again.  But, I'm working, at times, at least.
corry
Quote from: corry on July 26, 2014, 02:00:29 AM
Thanks 00!
...Back EMF ? ...Resonance ? ...OU !??  :)
Using a 9 volt battery to charge a cap and light up an LED! A demonstrated dependence of the circuit on the inductance of the coil set! Yes, that's pretty neat! You're easily impressed!
Here, think about this then:
http://www.youtube.com/watch?v=BQi4jz2puio
Back EMF? Surely. Resonance? You bet, resonance galore in several stages of the demonstration. OU !??  Nope, just ordinary capacitor behaviour, combined with a clever wireless power transfer system.
corry
00 do not post off topic. He wanted to suggest something relevant.
