0 Members and 255 Guests are viewing this topic.
magpwr
Quote from: NickZ on August 01, 2014, 02:39:46 PM
  Tektron:
   I just received the two zener diodes that you sent me.  Great!
  They are made by CENTRAL  # CZ5355B.
  I've confirmed that they are the 18v, 5 watt zener diodes.
  Thank you very much.
   I will mount them later tonight, and report back concerning if they made a difference on the mosfet heating issue. I hope so...
   Thanks, again.
                          NickZ
   Magpwr: Can't really tell what your problem is with blowing the bulbs. Please at least upload a picture of your circuit. But, it sounds like the frequency levels are not right for those bulbs.
hi Nickz,
This is the version 4 the longitudinal experiment in the multisim and the final version released.
The input is 8voltsx5Amp(fused)=40watt to drive 120volts 2 x 250watt bulb at the max.All these after factoring the voltage drop at igbt and the 2 LC circuit tuned at 32khz and 64khz(2x input driver frequency)
The COP is 1250%
Lastly for curiousity sake i tried to use maximum DC voltage to max out the 2 x 250watt 120volts bulb before destruction.At 181volts the bulb would be destroyed.
180volts DC x 6.25Amp = 1125watt(Any higher the both bulbs 500watts would be destroyed)
Think about it 1125watt(Maximum power both 120volt 250watt bulbs can take)/40watt input power =2800% COP
Final virtual longitudinal experiment screenshot attached.
New topic would be created once the actual circuit is completed.It gonna be a long wait for components likely 1 month+.
I don't mind if someone proceed with live demonstration before me.
I am guessing Don smith device which i gonna resume working on is also based on "longitudinal wave" once resonance is achieved. :D :D :D
For anyone attempting to experiment please do not use cheap ceramic capacitors to do the job.3 or 4 mica capacitor need to be connected in parallel to form around 0.47uf high voltage rating the better.
The toroid or choke "100uH" needs to handle at least 3Amps there is no harm going higher 5Amp or 10Amp using around 18awg to create inductor.
Do make sure all the inductor have value close to "100uH" and the final capacitors value should be similar or close as possible.
Once more i need to mention L/C meter, scope and etc is a must have for this experiment.
xhacks
Hello,
I've tried to simulate your circuit but I get some errors, and I can't measure anything...Here's my schematic...
And here you can download my project http://goo.gl/etYMEb I've used Multisim 12
magpwr
Quote from: xhacks on August 02, 2014, 04:53:54 AM
Hello,
hi xhacks,
I guess you have not verified the component you selected.Holy "J" you were using 0.47Farad for the 2 capacitors.
I dunno why. :'(
Maybe my eyes deceived me. ;D
Please do tell me if you get it working with nice screen shot.Thanks.
So that the rest shall know.
TEKTRON
