0 Members and 278 Guests are viewing this topic.
NickZ
   Here is a video (below) that I made late last night, showing the basic layout of the Mazilli/yoke crt and it's connections to the Akula Air core and its coils.
https://www.youtube.com/watch?v=dAtricHslGk&feature=youtube_gdata_player
   I left my car battery charger connected all night to my 4ah battery as I've done in the past. However, this time the battery puffed out, big time. So, I think that a new battery is now in order, to continue with my tests.
NickZ
   I've been tuning the Akula air core tonight, by adding ferrite pieces to the inside of the Akula type of air core, as Geo had shown previously on his RMG.
What a difference it can make!
  I've also been testing different tuning caps, on the yoke's output coil side, that goes to the resonator coil on the air core. I've found a couple of caps that seam to be working well.
  Funny thing though, the 12, 4 aH battery which I thought had died last night, came back to life. Even though it's all blotted up, and all, it still works. Only now, if I find just the right position of the ferrite pieces inside the air core, as well as the best working tuning caps, and also connect HV to the output of the air core, the Fets don't heat up, only to luke warm. Like babies milk. LOL~~~
  Anyway, I don't really know what is going on yet, but I'm starting to see that there is something anomalous to all of this. I hope I can keep it up, further avoiding the fet heating issues.  Just thought that I'd past it along...
NickZ
  I couldn't add this picture to my last post, since the "modify" buttons have been removed. What's up with that???
  Anyway, here is a pic of my set up lighting a single 100w bulb. Tonight I further tuned it and got it lighting up 3 100w bulbs now. This is still with insuficient coil turns, as I've not been able to obtain more wire yet, but I will.
magpwr
Quote from: NickZ on August 09, 2014, 01:10:26 AM
hi NickZ,
I am glad you have made some progress in your work.Believe in what you do and don't let others dither you. :D
Tips for the day -"We need to work for success else success will never come to you"
In the meantime i have successfully replicated and uploaded in my youtube channel one of the 2 circuit board for Don Smith China replication-
Variable High Voltage supply board 150volts-1600volts.(Prototype)
http://www.youtube.com/watch?v=MknH42t0IGw
I have attached the original circuit board picture of the Don smith China- Variable HV supply board-500volts-1600volts.This is found on page 285  latest edition of pjkbook.pdf
There are more component used because the non segmented transformer in their version only generates around 500volts.
I used segmented transformer shown in my video which needs less than 300turns to get max 1600volts to protect capacitors.But it can go higher around 1800volts.
The MC34063 most likely used in their circuit provides the variable voltage control and boost output voltage from transformer 500volts to Max 1600volts.
The original circuit board used more components to achieve the same function.
Warning-The multimeter used in my experiment mentioned only 500volts but i find that it can display anything below 2000volts.But i don't recommend for anyone to use any 500volts rated multimeter for "HV" outside this project  .
NickZ
  Magpwr:
   Thanks for your comments.  It looks like there are only a few of us actually working on some circuits these days. I guess most others are waiting for a guarantee that what they are going to build, is going to work.  Well,  keep waiting...
   I'm still tuning away.  Yes, it takes some time. But, time is about the only thing that I have plenty of. At times...
  I was trying to adapt a 12v florescent bulb circuit for my HV pulcer, but I blew one of the smaller caps. It went of like a firecraker. Bang, right in my face. Any ways, so much for that.  I'll try something else.
  I with that I could just buy the two needed adjustable pulser circuits, connect them to my coils, and be done with it.   Wishful thinking, again.
