0 Members and 633 Guests are viewing this topic.
magpwr
Quote from: mscoffman on August 15, 2014, 10:21:30 AM
I found a valid capacitor!  Mouser/Wima 0.47uf  1KVDC claimed function: snubber high current
I found a half value capacitor that is a Hi-Q 2KV transmitting capacitor, I'll bet it's expensive with a long deliver time.
Some inductors from China.
magpwr,
I don't intend to do much more unless the project somehow disappears. I will use your suggested IC's if I were to do more.
While it's not very common, I will offer to *Fund* certain aspects of your project if it would help you. For example to find
the highest Q LC's by trying more manufactures components, or do the project quicker, or better, Like printed circuit boards ect.
Don't hesitate to communicate with me and ask if you come across something worthy.
:S:MarkSCoffman
People like to build simple DC to AC square wave inverters out of a twelve volt CT transformer and a couple of FET's as per youtube.
If they were to build a second order modified sinewave inverter, That waveform is: +,off,-,off... with timing closest to a sinewave from
an FET H-bridge then attach it to an acid/lead battery without a filter cap. One would get an AC 120Hz pulse stream directly from the battery.
This is well within the range that anomalous discharge characteristic of acid/lead batteries seem to occur. Caution would be indicated but
would be an interesting thing to try.
hi mscoffman,
I found the best modern alternative besides mica capacitors after doing some research in radio sites.I have made serious $$ mistake by buying metalized capacitor.
Please avoid metalized version at all cost as these capacitors at high frequency would have inductance effect.
We need to go for recommended type of capacitors foil/film based.
The induction heating capacitors is the best choice reason because of it's low ESR and it's Polypropylene Film."Source ebay  seller China"
Typically 1200VDC Rated.
The best is of course Teflon and mica capacitors.I have seen Teflon capacitors sold in ebay but it's expensive.
Please avoid using PWM generator at the initial stage of the experiment due to slight frequency stability issue.
I find that using signal generator set at 3...4% duty cycle is able to provide necessary signal to TC4428(1.5Amp rated) even via 1 x 1k resistor connected to both input of TC4428(22volts max).Both input channel is of I/C:TC4428 is tied together.
I would prefer to fund my own project.Thanks for the support anyway.
I will now create a new topic -Longitudinal Wave Experiment to demonstrate Overunity
Please follow me over in the new topic.
I have broken the 5Amp  barrier(40watts down to 12watts estimate) and now with my version 6.0 its runing on <2Amp at 6.6volts powering 750watt bulb instead of 500watt bulb.
"It looks like i was hijacking this Dally topic"
:D :D :D
Thaelin
   Been hunting for the new forum but cannot find.
Can you post a link here?
Would like to follow you as well.
thay
magpwr
NickZ
   MenofFather:
   Have you built the circuit below? If so, what were your results?
   I notice that this is the same circuit that Ruslan is using on induction part of his circuit. It is much simpler version than the Akula's second video crt.
  Do you know why the crossover diodes are not the same, as in Ruslan's diagram?
   Do you think that using IN5408 diodes as the crossover diodes would be ok?
   Are the R1-R4 resistors 7.5 ohm?  I have several of the 3 watt or 5 watt 460 ohm resistors that I use on the Mazilli crt. Would those work in place of the 7.5 ohm resistors?
   Do you think that the ideas for a circuit mentioned above can be used similar to the Mazilli crt, even without the duty cycle, and frequency adjuster 494 and other IC, for now?
MenofFather
Quote from: NickZ on August 23, 2014, 10:44:43 AM
   MenofFather:
" Have you built the circuit below? If so, what were your results?"
Yes, I build, but I not get overunity.
My results is in some places (video), but I now have slow internet, to search them.
"Do you know why the crossover diodes are not the same, as in Ruslan's diagram?"
That is crosover diodes?
" Are the R1-R4 resistors 7.5 ohm?"
R3 and R4 is 7.5 ohm. R1 and R2 I not see in schematic.
" I have several of the 3 watt or 5 watt 460 ohm resistors that I use on the Mazilli crt. Would those work in place of the 7.5 ohm resistors?"
It works on low frenquency (100-1000 Hz). On hight frenqency it can not wok good. It can work maybe on not more that 10-30 kiloherc. So better use at least 70 omh resitors.
" Do you think that the ideas for a circuit mentioned above can be used similar to the Mazilli crt, even without the duty cycle, and frequency adjuster 494 and other IC, for now?"
You can use Mazili, but then you need made same mazili resonance with series resonance, so for you harder be made series resonance. And duty cycle is not inmportant in TL in Ruslan Divice. :)
