0 Members and 633 Guests are viewing this topic.
Jeg
Thanks Nick, I wish this year to be more productive!
Menof, how thin is the pulse from your nanosecond gen? What its voltage peak?
I had some time the last few weeks and I collected some interesting quotes from Tesla that might inspire someone. All taken from his interview on his work with alternating currents
1. Tremendous advantage to break at the peak of the wave... page 56
2. Damped wave is of advantage. With a gen of 1Kwatt it gives an activity of 5Kwatts. Page 62
3. If you have a continues or undamped wave 1Kw gives you only wave energy at the rate of 1Kw! Page 62
4. Those experiments with powerful' discharges were mostly performed in this way, with a few primary impulses and superimposed quicker  vibrations. Page 92
5. Working with damped waves we can produce wonderful effects. Operating with undamped waves we have to stick to the actual capacity of the machine. Page 92
MenofFather
Nick,
" When you say that you don't have OU, does that mean that your device did not self run?"
Yes. But did you can not answer this question to youself? Ниужели так, неужели ещё ндо задавать вопрос дополнительный, если я написал ,что сверхединицы не получил?
"  MenofFather:  The purpose of the 18v 5w zener diodes (Mazilli) is to be able to run the crt at voltages higher than just at 12v. Such as 24v to 36v, without burning the Fets. But, that may not be the case if using only the 6.2v zeners while running the crt at higher voltages, without the duty cycle controller.  What do you think?"
Use 12-18 volts zeners or not use them. I not using them and my generator on TL with mosfets work wery long. Выброси эти стабилитроны, я их не использую для низкочастотной накачки и акуратно пользуясь ничего не будет гореть, стабилитроны только нагромозждают вид и не красиво выглядет и больше где-то ошибиться их прикрепляя, а так они всё равно не спасали от згорания транзисторах у меня, может редко спасали, не помешает, но не надо на их много надежд вкладывать, что от этого не будут гореть транзисторы.
MenofFather
Quote from: Jeg on August 31, 2014, 12:41:03 PM
Nice to see that u are still here guys! ;) After my vacations i started yesterday to built this circuit. I am just thinking the case that  these two zeners are not for gate protection but for making a specific operation point for the mosfets. Anyway i will test it the next days and i will report my findings.
Menof, i will check your videos later cause i am at work, but i wonder what went wrong in your case and you didn't find something hopeful with this circuit. What i realized is that at the output coil someone has to connect the bridge/caps/load first, and then to start winding until the targeted power at the output. Without load connected the output can reach even some thousand volts but with load the output can be very low and not able to do anything.
You can not check my videos, because it in russian and you not understanf probarly they.
" didn't find something hopeful with this circuit."
That circuit?
MenofFather
Quote from: NickZ on August 31, 2014, 01:26:40 PM
  Jed:
  Good to hear that you are still at it, also.
   I watched the videos that MenofFather just upload the links to.
First thing that I notice is that the windings on the yoke are not the same, that is,
5 or 6 turn (or so) on each side of the center tap of the primary coil. Then 20 or so turns on the yoke secondary coil. And 3 turns on the yoke's second secondary coil,
at least of what I can see of them.
  The yoke is the most important part of the circuit, in order to get several 100 watt bulbs lit brightly. And the relation of the yoke coils to the air coils is also very important.  Looks like you are not using a resonator coil (12 + 12 turns) mounted on top of the 48, 48,  24,24, 12,12 turns air coil. Which is what is giving this output coil its magnetic induction.  I would suggest using the same coil winding pattern as is being used by Kapanadze/Akula/Ruslan. I also don't see a Kacher circuit giving the HV pulses to the air coils output coil.  But, as I can't understand what is being said in the video, I'm sure I've missed some things.
  MenofFather, please hold the camera steady, use proper lighting, and speak louder, so that at least some of us can see and understand what is being shown.
  Thanks for showing us your work.
Divice with kacher is here https://archive.org/details/MVI2492
I made many times divice with kacher and with pulse and every time I not get more out than in.
"5 or 6 turn (or so)"
Is 10 turns or so.
"48, 48,  24,24, 12,12"
Is 56, 56, 28, 28, 14, 14 - something like this.
MenofFather
Quote from: Jeg on August 31, 2014, 02:46:19 PM
I not have fast oscilioscope, so I can not chek that. My oscilioscope only 20 Mhz.
