0 Members and 115 Guests are viewing this topic.
Thaelin
  Hey all:
    There comes a time where you have to decide on where you stand and what you are willing to do.
I have hit that level. Since I have no more time to bench it, I have to make my feelings public. I have
long realized that one of the first Daly devices was different. It had a second coil on one side of the
dual winding and a cap on the other. This perplexed me for a long time. One day, I came across the
answer to that. A coil will move the phase angle in one direction while a cap will move in the other.
Seeing this has two windings, one with a coil and the other with a cap, that meant to me that each
had the phase moved in reverse to the other. If we have a pair of windings that move the phase into
equality with the other, bingo, we have now created a situation as if there was a pure resistive load
on it. Reactive to real power conversion may be the outcome. Damn I wish I had time to play but no.
Hope this will fall on the right ears as my bench is turned off and has been for a long time.
Thay
magpwr
Quote from: Thaelin on September 04, 2014, 04:32:22 AM
  Hey all:
Thay
hi Thaelin,
Thanks for the speech.No offends but it seems you kinda reminded me of "a ship which was sailing in yesterday's wind".
I understand your reasons "lack of time" to finally wrapped up your bench,let dust settle and eventually lead to equipment disposal in the future with or without your presence.
I'm curious on how things and always have been it's the primary reason why i took up electronics as my hobby around 12years old.
Hence it is why i love to reverse engineer sections of circuit board if i'm interested.
Your findings will be noted in my head.Thanks.
MenofFather
Hello all!
Сегодня проверил акулы схему ещё очередной раз, съёмная обмотка три с половиной слоя постоянно всё в одну сторону мотаеться и первые три слоя полные, поверх неё индуктор 1 слой полный и поверх него облучающая обмотка из шесть витков с зазором как у Романа. Я ничего не расчитывал, в смысле длины провода съёмной обмотки, надеясь, что вдруг получиться. трансформатор Тесла зделал не по принципу качера, а на одном транзисторе и CD4046 генераторе, где можно регулировать частоту, скважности нельзя. Трансформатора Тесла частота собственных колебаний около 1 мегагерц. Трансформатора Тесла нижний конец заземлён и заземлял съёмной обмотки и один и второй конец по очереди. Какой-то необычной прибавки не нашёл при работе трансформатора Теслы. Ну облучает он и ничего от этого по сути не меняеться.
That day I made replication of akula divice, but not get overunity. I use not kacher in that day, but Tesla coil with one mosfet and CD4046 generator. It frenquency 1 megaherc.
Void
Quote from: MenofFather on September 04, 2014, 10:41:53 AM
Thanks for the info on the test you tried MenofFather.
Really that should be about the same as using a 'kacher' oscillator to do the same thing.
All the best...
Thaelin
Mags
None taken, guess then maybe I should set sail for the sunset and drop out of the game.
If I am that far behind, then there really is no place for me
