0 Members and 776 Guests are viewing this topic.
NickZ
  Menof:
  Thanks for that explanation about what Akula and Ruslan are showing or mentioning.
   Sounds like it is possible to obtain usable results even without scopes, and other expensive test gear.  That's good news for many of us.
  I've been tuning my device by just using an analog voltmeter, and watching the intensity of the light bulbs, when I make any changes in the components or the coils.
MenofFather
Quote from: Void on September 08, 2014, 09:05:59 AM
Thanks for that MenofFather. If you have time sometime, if you can give a brief summary of what Akula was
saying about tuning in his latest video that would be great. It seems what Akula and Ruslan are doing in
regards to tuning is similar, based on what you said here for Ruslan's device tuning.
All the best...
I not agree with akula, akula wery dificult explaining simple things.
Akula puting oscilioscope and generator on one end coil and find frenquency resonance 1 megaherc. Then to second end addading ground and found resonance (then amplitude bigest) at 4.8 megaherc, but say, that that frenquency is too hight and then searching lowest frenquency and finding 1.8 megaherc. And then Need made Tesla coil with resonant frenquency 1.8 megaherc. And on that frenquency need ajust that capasitor (9:59 he cicling it). Путанно правда? :)
And then he say, that if we knowing frenquency of Tesla coil, frenquency of capasitor, we can determinate, that harmonic use for low frenquency. But I suggest, that low frenquency can be basicly any. Low frenquency must be 3 or 6 times lower. He say then, that can made more that coil, on diferent tubes. And without ground find they frenquencies, and then you add ground you must find practicly same frenquencies [1,8 megaherc]. They can be little diferent. 18 kiloherc, must good variant he saying. "But I making on 32" - he say... Порог до 32, дальше падение амплитуды. No more than 32 kiloherc. If more amplitude gose down. On air transformer less, than 17 kiloherc going down no reason. Translation to about 16 minutes to flying blue circles.
magpwr
Quote from: NickZ on September 08, 2014, 09:45:32 AM
  Menof:
hi Nickz,
To be honest the circuit is easy to replicate without the coil portion as mentioned by me months back.
But without knowing what waveform\signal\frequency and at which various point was the measurement was taken from it's gonna be mission impossible task.It's the reason why i am still staying away from this device replication."There is insufficient input for me to carry out the replication task" :D :D :D
Lastly coil winding details is still little confusing.
Every portion of the circuit needs to be clearly understood before even thinking about replication since probability of a failure at this point would be very very high.
Unless someone got the time to test one by one in order to replicate the signal as shown in video using the scope.
In the meantime while waiting for some exotic components to arrive.I believe i have cracked the mystery of the Don Smith China primary driver stage which was powered by bank of capacitor(450voltsx4 120uf) and switched via 6x IGBT.The large toroid which can handle high frequency would be around 4mH.In actual circuit it is connected to 6x igbt source (6XIGBT in series).The 6x igbt drain is connected to 1nf Door knob capacitor 10KV.
But for virtual i merely swapped a little to save time while maintaining estimated capacitor/inductor value in order to observe waveform which would appear at L/C primary coil.
Void
Quote from: MenofFather on September 08, 2014, 11:57:27 AM
Thank you MenofFather. That helps. What was Akula talking about in the last part of his video
where he was talking about the 'Front' of the waveform? I couldn't follow what he was talking
about in the last part of the video just by watching the video.
All the best...
Jeg
Quote from: NickZ on September 07, 2014, 11:31:09 PM
  Guys, do we really absolutely need the nano second modulator controllers,  or not?
Who knows...  Seams to me, that the same effect should be possible to see, even without it. But, possibly without the device able to self run.
  Kapanadze does not show having a scope, GeoFusion doesn't own a scope, Ruslan says he hardly uses it. Maybe it can be done without having one, which can allow more of us to give it a try.
Nick, if you go just with the 494 / 2110 circuit you don't need katcher. The same effect is here but without oscilloscope just forget it.
