0 Members and 152 Guests are viewing this topic.
Void
Quote from: MenofFather on September 09, 2014, 03:29:48 AM
In last part talking of not important things, about that choke on ferite road, who is betwen secondary kacher coil and antena.
That  choke making wery fast rise time, it compressing and making 36 kilovolts or more pulse, but I not bealive in that.
Ruslan say, that sometimes without it (choke) better work.
But all depends on ground.
Thanks MenofFather for taking the time to explain about these videos.
That really helps. So Akula said he was using the choke to make his HV pulses.
That is interesting. All indications are that Akula based his first couple of self running devices
closely on Daly's device. Ruslan based his device closely on Akula's device and on Daly's device as well.
All three of these devices seem to work on the same principle. I will do some experimenting
with this and see if I can get anything interesting. If there really is something to this, it shouldn't
be too much longer before other people start to get some results of some sort as well. :)
All the best...
Void
Hi Acca. Thanks for posting those Ruslan comments.
Every little bit of info may help.
All the best...
T-1000
Quote from: Acca on September 09, 2014, 05:50:27 PM
Rusaln Kulabuhov free energy device
https://www.youtube.com/channel/UCwVT-3hF29an4vZOz7nGOwg
below is the latest coil form of Ruslan..
http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=1080#236944 -
"Святолуг ,ну что вы тут ищите ? Витки считаете ?  (http://www.realstrannik.ru/media/kunena/emoticons/laughing.png)  Индуктор намотан проводом 11 м 2,5 мм поверх обычной биф-катушки. Она тоже 2,5мм проводом намотанна (http://www.realstrannik.ru/media/kunena/emoticons/unsure.png)  Индуктор в резонансе на частоте 17,2 кГц
Качер тут для разгона частиц и разгрузки инвертора. Он заряжает катушку и от туда прибавка. Принцип тот же что и с наносекундами. Просто я выкинул наники нафиг (http://www.realstrannik.ru/media/kunena/emoticons/dizzy.png)  Заколебало постоянно менять транзистор. С другими не работало... Что ещё рассказать ?
Ок !  Генератор пуш-пул обычный (http://www.realstrannik.ru/media/kunena/emoticons/wassat.png)  Можно на ТЛ494 собрать  (http://www.realstrannik.ru/media/kunena/emoticons/wink.png) Мотаем феррит : для пуш-пул по 6 витков (2 вольта виток) 28 витков 4мм провода для энергии через катушку , 3 витка для резонанса ЛЦ и кондёры 0,47мкф 2штуки + ещё один надо паралельно подобрать... Может и не надо будет. Далее ...
Блок питания -импульсник 3-6 ампер 12 вольт хватает вполне (http://www.realstrannik.ru/media/kunena/emoticons/whistling.png) Пропеллер от компа 12 вольт для охлождения. Качер (не очень хорошая задумка) Бровина на частоту до 2х МГц !!! Надо подобрать по катушке в резонанс. Вот тут пороаботайте головой (http://www.realstrannik.ru/media/kunena/emoticons/wassat.png) Например конкретно в этой системе 37,5 м длинна провода или 1/2 волны !!! То есть катушка настроена как полуволновая антена на 4 МГц , ищем резонансную частоту. Она была у меня 2 МГц  (http://www.realstrannik.ru/media/kunena/emoticons/blush.png)
А дальше проще не бывает.... подрубаем осла и начинаем сводить всё в кучу. Земля (провод) тоже 1/2 волны от 37,5 м =18....М ! Надо создать отражёнку вкатушке и чем больше , тем лучше  (http://www.realstrannik.ru/media/kunena/emoticons/w00t.png)  Мощность больше будет + прибавка  (http://www.realstrannik.ru/media/kunena/emoticons/wink.png) Импульсы по осциллографу смотрим , чтобы попадали именно в горбик синуса. Чтобы вообще получить чёткий импульс ,нужен наносекундник. Из Теслы можно всё это получить ! Сделать её управляемой. Тут очень хорошо подойдёт схема Акулы (Романа) , он её демонстрирует в видео. Конкретно часть накачки самой теслы + индуктивная катушка + антена над индуктором. Если вы сложите моё пояснение + видео Акулы всё должно получиться  (http://www.realstrannik.ru/media/kunena/emoticons/wink.png)  Но на выходе этой установки будет не 50 Гц , а частота накачки 17...кГц. Опять же оговорюсь (http://www.realstrannik.ru/media/kunena/emoticons/wassat.png)  Система работает при хорошем заземлении. Земля нужна хорошая ! В этой установки у меня появился хороший плюс  (http://www.realstrannik.ru/media/kunena/emoticons/smile.png)  Больше не сгорает блок питания приобрыв земли. Она просто останавливается.
