0 Members and 150 Guests are viewing this topic.
MenofFather
"we must create OTRAZHENKU VKATUSHKE""
"we must create reflection in coil"
Void
Quote from: Jeg on September 11, 2014, 02:58:19 AM
In addition, at this new schematic that you posted...
a) what TR2 with 40 turns secondary is doing there?
b) Do you know what is the DC voltage supply at the primary of his yoke at 6+6 turns middle tap?
Hi Jeg. Ruslan's device appears to be closely based on Akula's second self runner.
If you look at the schematic Akula made for this device, it shows the same transformer
winding going back to his inverter driver. Ruslan may have copied from Akula's schematic
and modified it, but I don't know if Ruslan is actually using that transformer in his own device.
See the relevant section in the attached excerpt from Akula's schematic.
All the best...
Jeg
Quote from: Void on September 12, 2014, 07:10:31 AM
All the best...
Void, you are a really good detail tracer! Thanks a lot.
Menof.. ;)
NickZ
  I believe that the 40 turns coil that goes back to the inverter, is used only for the feed back path.
  As the bigger coil of the yoke's two secodary coils is showing only 30 to 60 volts output to the air coil. The other (3 turns) secondary yoke coil's output must be lower voltage but higher amps than that. But, then how can he light a 220v 10watt bulb, from the output of the 60 volt output coil, which is also rectified to DC?
Does not make sense to me.
  Guys, you are comparing two different schematics from two different type of devices. The schematic that Ruslan uses now for his more resent Akula second video type replication, is not the same as the one that he used for his earlier Daly device replication.
