0 Members and 119 Guests are viewing this topic.
Void
Hi Nick. Have a look at the latest schematic just posted for Ruslan's latest circuit, and you should
see what we were referring to. Ruslan's circuit is quite similar to Akula's second self runner, but Ruslan
has made some changes. According to the schematics Ruslan apparently posted, he is actually driving the load
output coil windings on the air core transformer directly in series with the 28 turn secondary winding on his yoke core.
The effect of the HV kacher pulses is supposed to boost the output power, so it may well boost the output
voltage across the load to a higher voltage than you might expect, assuming this really works as claimed.
All the best...
NickZ
  Void:
   Yes, that's the assumption...
   Ruslan is driving his air core output coil which is 24,24, 12,12, 6,6 instead of  the previous (48,48, 24,24,12, 12) that he had shown, from the yoke's 28 turn secondary coil, along with the bulbs is series, as well as an earth ground.
That's really different than how he showed the previous set up.
  My yoke's 20 turn secondary coil's output is about 80 volts, although my meter can't measure it,  I just look at the 100w bulbs lumin levels, as an indication of probable voltage and current readings. This yoke's output by itself will light my 100w bulbs to about 40%, or so brightness levels.
  So, to go from my yoke's 20 turn secondary coil, connected in series through a tuning cap, to my air coil's output coil, which has 168 turns on it,  should give a healthy output.  Plus, having the kacher/exciter on top, to boot.
  We'll see...
  Each circuit diagram that Ruslan, or Akula are coming up with, is quite different, and also more complex than the previous one.
Makes it hard to try to keep up with these guys.
Void
Quote from: NickZ on September 12, 2014, 07:37:36 PM
  We'll see...
You are doing well considering you don't have a scope.
For sure there are a lot of circuit variations out there, although these particular devices
all seem to be all closely related. I am running some tests as well as I have time.
All the best...
Jeg
Quote from: Void on September 12, 2014, 10:37:55 PM
... although these particular devices
all seem to be all closely related...
Void, do you know what parts are these inside the red cycles? Especially the first one which is at the mosfet side?
Good lack with your tests..
Jeg
Ok i located the first component which is a varistor for protection.
http://www.datasheetarchive.com/dl/Datasheets-UD3/DSAUD0042608.pdf
The second part perhaps is a thermistor. Does anyone understand why thermistor, and why there?
