0 Members and 334 Guests are viewing this topic.
Void
Quote from: NickZ on September 15, 2014, 10:18:08 AM
  I put a diode on my earth ground connection that goes to the Kacher, that I use on my Mazilli crt.  No change in the way that the Kacher works, and not much added brightness to the bulb, in either direction of the diode.
Yes, I have seen the same thing. I put a 1 ohm current sensing resistor in the earth ground line
and viewed on the scope, and it is a sinewave when the waveform on the secondary winding is a
sinewave. Since it is AC, it should still pass current with a diode in either direction.
All the best...
MenofFather
"...Any tips on how the secondary should be wound to match what Akular/Ruslan are doing?"
Output coil in Ruslan latest divice is like Kapanadze blue coil. But I try that coil and not get overunity. Here no magic coil probarly. Here need made properly ajustion. Just one coil like Ruslan not give to you overunity.
T-1000
Quote from: a.king21 on September 14, 2014, 04:27:11 PM
The technical term is stochastic mixing.
In way Akula and Ruslan is using that is making standing wave inside of bifilar with one end from induction cooker style source + nanopulse source (from generator or filtered out Tesla coil signal to make huge 35kV+ spike on peaks for antenna) and another end as Earth for electrons pump...
And the concept used there is only one and best exlained by Tesla:
http://www.ussdiscovery.com/corum/corum/corum.htm
"...it became apparent that the fireballs resulted form the interaction of two frequencies, a stray higher frequency wave imposed on the lower frequency oscillations of the main circuit.... This condition acts as a trigger which may cause the total energy of the powerful longer wave to be discharged in a infinitesimally small interval of time and the proportionately tremendously great rate of energy movement which cannot confine itself to the metal circuit and is released into surrounding space with inconceivable violence.
It is but a step, from the learning how a high frequency current can explosively discharge a lower frequency current, to using the principle to design a system in which these explosions can be produced by intent." -N. Tesla
stupify12
To those who are willing to listen and contribute. Tesla have already given all the answer to us but we got stuck to his Tesla Coil..
Edison Effect!
Tesla
QuoteWell, in some of these bulbs I have shown, for instance,
that a heated conductor emits a stream of ions, or, as I said
at that time, charged particles, and a few of these bulbs I
have been using exactly in the same manner as the Audion(TRIODE) is
used today.
Tesla
QuoteEveryone that you see was built, not in one, but in
several forms; they have been experimented with and records
have been obtained with them. Among these bulbs I have a
great number of receiving devices, and some of them come
remarkably close to those which others have used since.
QuoteCounsel
Is that drawing [Fig. 94] a part of the patent application
or intended for an application?
Tesla
Yes, but it was never filed.
Tesla
QuoteIt is well known that certain radiations(Emission)—such as those of ultra-violet light, cathodic, Roentgen rays, or the like—possess the property of charging and discharging conductors of electricity, the discharge being particularly noticeable when the conductor upon which the rays impinge is negatively electrified. These radiations are generally considered to be ether vibrations of extremely small wave lengths, and in explanation of the phenomena noted it has been assumed by some authorities that they ionize or render conducting the atmosphere through which they are propagated. My own experiments and observations, however, lead me to conclusions more in accord with the theory heretofore advanced by me that sources of such radiant energy throw off with great velocity minute particles of matter which are strongly electrified, and therefore capable of charging an electrical conductor, or, even if not so, may at any rate discharge an electrified conductor either by carrying off bodily its charge or otherwise.
Tesla
QuoteA simple way of supplying Positive or Negative electricity to the terminal is to connect the same either to an insulated conductor supported at some height in the atmosphere(Positive) or to a grounded(Negative) conductor, the former, as is well known, furnishing positive and the latter negative electricity. As the rays or supposed streams of matter generally convey a positive charge to the first condenser-terminal, which is connected to the plate or conductor above mentioned, I usually connect the second terminal of the condenser to the ground(Earth), this being the most convenient way of obtaining negative electricity, dispensing with the necessity of providing an artificial source. In order to utilize for any useful purpose the energy accumulated in the condenser, I furthermore connect to the terminals of the same a circuit including an instrument or apparatus(Kapanadze Outer Blue Coil) which it is desired to operate and another instrument or device for alternately closing and opening the circuit(Spark Gap). This latter may be any form of circuit-controller, with fixed or movable parts or electrodes(Spark Gap), which may be actuated either by the stored energy or by independent means.
That is the answer to those all speculation..
Meow ;D
Void
Quote from: MenofFather on September 15, 2014, 01:45:09 PM
Hi MenofFather. Sure, I agree that the coil itself will probably not give overunity, but it may be an
important piece that is required to achieve overunity. Ok on your test result regarding this.
All the best...
