0 Members and 619 Guests are viewing this topic.
Void
Quote from: T-1000 on September 15, 2014, 05:55:37 PM
In way Akula and Ruslan is using that is making standing wave inside of bifilar with one end from induction cooker style source + nanopulse source (from generator or filtered out Tesla coil signal to make huge 35kV+ spike on peaks for antenna) and another end as Earth for electrons pump...
And the concept used there is only one and best exlained by Tesla:
http://www.ussdiscovery.com/corum/corum/corum.htm
"...it became apparent that the fireballs resulted form the interaction of two frequencies, a stray higher frequency wave imposed on the lower frequency oscillations of the main circuit.... This condition acts as a trigger which may cause the total energy of the powerful longer wave to be discharged in a infinitesimally small interval of time and the proportionately tremendously great rate of energy movement which cannot confine itself to the metal circuit and is released into surrounding space with inconceivable violence.
It is but a step, from the learning how a high frequency current can explosively discharge a lower frequency current, to using the principle to design a system in which these explosions can be produced by intent." -N. Tesla
Hi T-1000.  Interesting. Yes, I will be experimenting with high frequency, high voltage pulses, as that seems to
be important in this arrangement.
All the best...
Jeg
Quote from: MenofFather on September 15, 2014, 01:45:09 PM
"...Any tips on how the secondary should be wound to match what Akular/Ruslan are doing?"
Output coil in Ruslan latest divice is like Kapanadze blue coil. But I try that coil and not get overunity. Here no magic coil probarly. Here need made properly ajustion. Just one coil like Ruslan not give to you overunity.
What is your high frequency and what is your wire outer diameter (bifi)?
NickZ
   MenofFather:
   The tips have already been given by Ruslan and Akula. You understand what they are saying, not like some of us.
   You need to match the Kacher crt frequency to the induction heater circuit output, so that the pulses aline on the peaks.   Have you tried to do this?
If so, were you able to match up the peaks together, or not?
  Without the two systems matching frequencies, or harmonics, there is only two inverters connected together, without any extra energy extracted from the ambient.
  Are you connected to an earth ground that is over 10 meters long?
   As there are several versions of the Kapanadze/Akula/Ruslan air coil, which coil version did you use?
  Ruslan's newest version of his air coils, use less turns. But, the magnetic cancelling effect may be very important, for a proper self runner.
T-1000
Quote from: NickZ on September 16, 2014, 09:35:56 AM
No need for 10 meters ground wire as the inductance of the wire is measured in a way which allow to match resonant frequency with the standing wave what gets created inside of bifilar coil - this was explanation by Akula in one of recent videos - http://www.youtube.com/watch?v=-rALEpvBQig
NickZ
   I watched that Akula video a couple of times, but, I really can't understand what he is saying.  It seams like a very important explanation of his second self runner crt.  I really wish that I could understand it.
  But, if the ground connection doesn't have to be over 10m long, then why does he have a long ground cable running to his metal pipe that is next to a water source. On ALL his higher output devices???  Just a coinsidence, I guess...
