0 Members and 619 Guests are viewing this topic.
MenofFather
Quote from: Jeg on September 16, 2014, 03:36:00 AM
What is your high frequency and what is your wire outer diameter (bifi)?
I try many hight frenquncies. 2 megaherc, 1 megaherc, 4 kiloherc.
" what is your wire outer diameter (bifi)?"
About that coil you speak?  About outup? If yes, then I try many output coil one is 2.5 mm2, other is about 1mm2, I not meashure wire diameter, maybe 4 mm in 2.5 mm2 wire, other maybe 2 mm.
MenofFather
Quote from: NickZ on September 16, 2014, 09:35:56 AM
   MenofFather:
   The tips have already been given by Ruslan and Akula. You understand what they are saying, not like some of us.
   You need to match the Kacher crt frequency to the induction heater circuit output, so that the pulses aline on the peaks.   Have you tried to do this?
If so, were you able to match up the peaks together, or not?
  Without the two systems matching frequencies, or harmonics, there is only two inverters connected together, without any extra energy extracted from the ambient.
  Are you connected to an earth ground that is over 10 meters long?
   As there are several versions of the Kapanadze/Akula/Ruslan air coil, which coil version did you use?
  Ruslan's newest version of his air coils, use less turns. But, the magnetic cancelling effect may be very important, for a proper self runner.
Kacher not have pulses, it have sine on secondary. So I think, here not need much pulses on peak of low frenquency sine.
"   The tips have already been given by Ruslan and Akula."
I akula tips translate to you, you also can translate with translator. Other that they saying is nothing important or blurly saying.
" Are you connected to an earth ground that is over 10 meters long?"
I tryed conect diferent groud lenght wires.
" As there are several versions of the Kapanadze/Akula/Ruslan air coil, which coil version did you use?"
Here is not easy explain. I try diferent coil. One coil like Ruslan in his latest video. Other coil like in akula schematic, but little diferent with 3 layers. But I think here key for overunity is not magic wound coil, but proper ajustion kacher with output coil, you must play with kacher windings, or with output coil windings and self capasistance and induction. But maybe I wrong.
Dally divice not have magnetic canseling efect and he get overunity, so probarly magnetic canseling efect is not wery important.
MenofFather
Quote from: NickZ on September 16, 2014, 09:42:28 PM
   I watched that Akula video a couple of times, but, I really can't understand what he is saying.  It seams like a very important explanation of his second self runner crt.  I really wish that I could understand it.
  But, if the ground connection doesn't have to be over 10m long, then why does he have a long ground cable running to his metal pipe that is next to a water source. On ALL his higher output devices???  Just a coinsidence, I guess...
Akula never say, that grounding not must be over 10 meter long.
d3x0r
Quote from: MenofFather on September 17, 2014, 07:27:04 AM
what translator works on sound file?
MenofFather
Quote from: d3x0r on September 17, 2014, 07:35:24 AM
I mean translator for Ruslan words in diferent places. That akula saying I translate. He much speaking, but wery small saying practical things.
