0 Members and 343 Guests are viewing this topic.
MenofFather
"...A battery terminal? ...."
You can put ground to battery if that betery gose to ground.
Jeg
Nice progress and info sharing guys!
Menof i asked about frequency and wire outer diameter so to calculate for you the right diameter of your core so to make it on the exact wavelength. But i guess that you already have considered about that. If not just tell me. But again, this is not enough by itself and i will explain why.
I made four coils (magnetic canceling) 48-48, 24-24, 12-12
Each coil has a different core diameter and every time is calculated for a specific wavelength.
For making it vibrate at 2MHz for example, i used the wavelength of 8MHz! But when i measured it using a generator sinewave and an oscilloscope, i saw that it resonates to 1,7MHz. The reason for this is hiding behind the intrinsic capacitance and self inductance combination. It is very very difficult to wind it as to match the specific wavelength vibration to the right inductance and capacitance characteristics. My opinion is that If you just adjust your katcher frequency to 1,7MHz then you loose the game. What we have to do is to correct this 1.7 MHz vibration by putting in parallel with the bifi coil some capacitors to tune it to a lower than 2MHz subharmonic. When this is done properly, then you will see a rise at the output much higher than that of letting it vibrate at 1.7MHz. As you understand, to take the shit out of this bifi coil, you have to tune it to a related subharmonic to the exact wavelength of your output coil. The difference is at least the double output. In some cases more than double...
Menof thanks for reminding us about dally not magnetic canceling output coil. The only difference is that you can not tune it to a high frequency due to the high inductance and intrinsic capacitance of it. But still the same rules apply.
MenofFather
Я теперь не имею возможности померить внешний диаметр провода.
But Akula nothing say about wire lenght. So wire lengh can be not so much inportant in this free energy divice.
Acording Akula, Tesla coil frenquency (with ground and without antena) must be like output coil frenquency (with ground seems) in his explanation video (УСТАНОВКА №2).
I not have sine generator. Akula, use, I see, sine generator in that video (УСТАНОВКА №2), then cheking frenquencies.
MenofFather
Я повторю ещё как похоже должен работать этот бестоплевный генератор.
Сперва нужно без качера добиться, чтоб от трансформации или с пропусканием через катушку тока лампа 220 вольт горела на полный накал, какая нибудь не мощьная, то есть, чтоб от самой трансформации на холостом ходу было 220-250 вольт. Потом добавить больше таких ламп, то есть нагрузить сильнее установку в 3-5 раз и подбирая для качера всякие вторичные катушки или съёмную перематывая добиться чтоб либо яркость вырасло при работе качера, либо чтоб потребление упало.
I try repeat again. that seems need do to make work free energy divice.
First need get without kacher on output 220 volts, that lamp, let say 220 volts and 20-40 W shine on full brightnes (withou kacher!)
And then need play with kacher secondary coil or output coil, wound kacher secondary coil with diferent numbers of turns or secondary coil with diferent turns and\or on diferen pipe diameter with conected to output coil much higher load and checking then output power be biger than input.
Jeg
Quote from: MenofFather on September 18, 2014, 04:44:09 AM
Akula doesn't say about this but this doesn't mean that it is not like this... Look what Ruslan say:
Качер (не очень хорошая задумка) Бровина на частоту до 2х МГц !!! Надо подобрать по катушке в резонанс. Вот тут пороаботайте головой (http://www.realstrannik.ru/media/kunena/emoticons/wassat.png) Например конкретно в этой системе 37,5 м длинна провода или 1/2 волны !!! То есть катушка настроена как полуволновая антена на 4 МГц , ищем резонансную частоту. Она была у меня 2 МГц  (http://www.realstrannik.ru/media/kunena/emoticons/blush.png)
А дальше проще не бывает.... подрубаем осла и начинаем сводить всё в кучу. Земля (провод) тоже 1/2 волны от 37,5 м =18....М
Don Smith says the same..
The real tuning is the one on the wavelength frequency or to a subharmonic of this...
