0 Members and 575 Guests are viewing this topic.
NickZ
  Both Akula and Ruslan use long earth ground cables, much longer and thicker than they need to be, to connect to their earth ground point. This is on all their latest higher power output devices.
  What happens if they disconnect that ground cable? No power output? Or just less output power? I think that the device will not work, or they would have disconnected the ground cable, to show that it still works.
   I don't think that trying to tune to a certain starting frequency is the way to go. As that will be different on each device, and each set kacher/yoke circuits.
   Tune the yoke's induction coil output for best output first, then tune that to the air core's output coil for maximum output between those two coils.
  Then tune the kacher to produce the highest output (lumins) at the aircoil's output coil, which also goes to the bulbs. Look for increased bulb brightness, instead of highest voltage.  As at least on my device, each additional bulb added to the circuit, changes the parameters. So, then find which combination of bulbs produces the most lumins.
  Tuning these devices for maximum output from each set of coils, by adding or removing coil turns, and the use of tuning caps in parallel, or series, to increase bulb brightness, is most probably what it needed.  Then use your frequency/duty cycle modulator circuits to further tune to highest output/least power consumption.
  That is what I'm trying to do. Even without a scope, signal generator, meters, etz...
MenofFather
" What happens if they disconnect that ground cable? No power output? Or just less output power?"
In last Ruslan divice (with kacher Brovina), then he disconect ground cable, divice just stop working.
Long ground cable can be important.
starcruiser
The more I read and see here with these we are back to RF theory and design. Look at the people who made these devices, all seem to have this as a background correct? So if you want to play with standing waves (SWR) in the coils then treat them like antennas and balance them according to the work to be done.
This means wire mass plays a role to the antenna design, do not discount this. Do we need to change the "balance" of the ground plane to generate the power? while controlling or maintaining the SWR we want/need?
Something to think about
Regards,
Carl
forest
What about the test made in the forest in the country area ? I saw video , just forgot who made it Akula or Ruslan.
Acca
