0 Members and 575 Guests are viewing this topic.
NickZ
 Ruslan is making changes all right. It's a different, whole new circuit.
I think, that it's the one that his latest schematic is showing. Or not?
   It would be good to know what the output voltage and current readings levels are. That are going through the output coils of both the Kacher, as well as from the magnetic induction oscillator crt.
  35kv at the Kacher antenna?  I doubt it.   But, maybe...
  Ruslan's new circuit goes from the induction crt throught a cap to the output coil on the air core, not to the smaller bifilar air coil, (bifilar input coil).
  That's the way that I had my Mazilli/yoke connected to the Akula/Ruslan air core set up for best output.
I could never get it to work well like Akula has it, with the magnetic induction current going to the bifilar air coil.
T-1000
Quote from: Jeg on September 19, 2014, 09:17:54 AM
T1000 you mean that katcher is able to produce a 35KV+ output at that MHz range frequency???
No, but with help of filtering choke you can chop off spike of few nanoseconds range out of sine wave which is being produced in Tesla coil.
@TinselKoala - please show some work on the topic as discussions only about how to make a fake won't get you anywhere.
The way Akula explained in his latest video was - he showed bit about finding resonant frequency in coil as antenna then attached ground (his scope is grounded too) and showed how resonant frequency changed. Then he took lower frequency harmonics which was in kHz range and this was a resonant frequency for induction heater circuit (17-35kHz) and using spikes with a frequency of Tesla coil on 1/3rd resonant frequency of output bifilar coil with ground. All ties up with with sine wave on kHz range with spikes on peaks...
NickZ
  So, does this new circuit from Ruslan represent what was shown in his latest schematic? The one which MenofF says is not from Ruslan.
  This shot is taken from his pretty blurry video.
starcruiser
It looks to me as if he has redesigned his device using new PCB's. He is consolidating his design, probably the same circuit just laid out differently. The above photo looks to be the high freq PSU control with phase adjustment sections. The pulse generator is in the box closest to the air coil (short wiring required). The other stuff is tuning caps and the PSU to drive the thing (I would use a DC setup myself with a stock inverter)
I would focus on the operation and theory, this one is still a HV impulse generator which is phase locked to the HF PSU to increase effect. The coils on the air-core coil form are tuned to harmonics of each other. this is a modified SST drive system with a home built inverter.
Now is this design/setup OU, don't think so but it is all about the the PF and Reactive power IMO
Regards,
Carl
MenofFather
Quote from: Void on September 19, 2014, 09:59:09 AM
Can anyone give an overview of what Ruslan was saying in this video?
Looks like he is making some changes?
He saing that remove not use inductor (primary coil on tube). Without it much better. He puting voltage 15 kiloherc directly to one coil on tube. If need, I can draw, how about is.
