0 Members and 824 Guests are viewing this topic.
Void
It looks like Ruslan has decided to do away with the 'kacher' tesla coil arrangement
now, and is going back to trying to make impulses directly.
Ruslan wrote the following:
http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=1386#238482  )
Святолуг , я не то чтобы спешу.... Я просто ухожу от килогерцев напрочь.
Не удобное напряжение ни в одном случаи. Индуктор я убрал и больше не хочу этой фигни :whistle:
У меня на много лучше результат без индуктора сейчас. Как и сказал ммс , решений полно.
Просто надо знать,что вы делаете. А выходное напряжение может быть разным (с ферро-сердечника)
Вопрос не в этом !!! Как вы получаете ВВ и ВЧ :)
Качер в этом случаи тоже теперь мимо :huh: Работаю над нормальным импульсом. И чем ниже частота,
тем ширеи сильнее этот импульс.
Google Translate gives this:
Svyatolug, I did not mean to hurry .... I'm just going to completely kHz.  Not comfortable pull in any cases.
I removed the inductor and do not want this garbage :whistle:  I have much better results without the inductor now.
As said, mms, making polno. Prosto need to know what you are doing.  And the output voltage can be different (with ferro-core)
is not the question !!!  How do you get BB and RF :)  Kacher in that case also now past :huh:  Working on a normal pulse.
And the lower the frequency, the stronger the impulse shirei.
What Google Translate produces comes out quite a bit as gibberish,
From the above translation, it sounds like Ruslan is not going to use a kacher
driver and coil any more, but create impulses another way...
A person can get lost in all the different coil and circuit variations that are
getting thrown around, so what I am focusing on instead is running very basic experiements
to try to find what the basic principle is that supposedly gives overunity here.
Basically it appears from descriptions that the requirements are high voltage pulses (KV) applied
right on the peaks of the low frequency inverter sinewave, but also the frequency relationships and coil
resonant frequencies seem to be important as well.
Jeg
Quote from: T-1000 on September 19, 2014, 10:37:07 AM
No, but with help of filtering choke you can chop off spike of few nanoseconds range out of sine wave which is being produced in Tesla coil.
This is cool! Do you have any link to learn about this technique?
Menof thanks for the drawing
Void
Quote from: MenofFather on September 19, 2014, 01:05:37 PM
If need schematic, it here:
Thanks!
Are you sure that Ruslan is driving the 'bifilar' multi layer coil with the series resonant
winding arrangement. Last drawing from Ruslan showed two secondary windings on the yoke core.
One to drive the air core bifilar winding directly, and the other winding for the series resonance
going to a primary winding on the air core. Are you sure there are still not these two secondary windings on the
yoke core?
MenofFather
Only on that place load I do not know.
