0 Members and 85 Guests are viewing this topic.
MenofFather
Quote from: Void on September 19, 2014, 01:09:15 PM
Thanks!
Are you sure that Ruslan is driving the 'bifilar' multi layer coil with the series resonant
winding arrangement. Last drawing from Ruslan showed two secondary windings on the yoke core.
One to drive the air core bifilar winding directly, and the other winding for the series resonance
going to a primary winding on the air core. Are you sure there are still not these two secondary windings on the
yoke core?
" Are you sure that Ruslan is driving the 'bifilar' multi layer coil with the series resonant
winding arrangement?"
Yes. If not be resonance, then he not show to us sine. But I beliave, that you can not use series resonance like in my draw, just put 220 volts trought output coil.
" Last drawing from Ruslan showed two secondary windings on the yoke core."
Ruslan never give any drawings. In previuos divice, he use two secondaries, but now one secondary, if it is, can be romoved.
" Are you sure there are still not these two secondary windings on the
yoke core?"
Shore. Only can it be on video from prieviuos expirements.
magpwr
Quote from: MenofFather on September 19, 2014, 01:18:49 PM
Only on that place load I do not know.
Hi everyone,
We need to to come up with systematic approach in building a kapanadze device stage by stage successfully.
We need to first start with the Yoke Core.
I recalled base on one of the Akula older video with him holding a yoke core in hand.He mentioned that not all yoke core is suitable.
If anyone recalled there is 2 yoke core highlighted in the video.
We need to come up with a proven way in order to determine if we are using a suitable yoke core.
One method is Nickz approach earlier version to save testing time or go with lithunia example rubin yoke core experiment.
The reason why i keep mentioning this is to narrow down the possibility of a failure at various stages.
This would be the approach i would take if i am building this device.
It would be pointless building 2 or 3 stages in one go then get stuck if you are unable to find the root cause of the problem.
Acca
 Valery Belousov shows how the ground is very important in the energy function.
Oh it's in Russian also !!
http://www.youtube.com/watch?v=hvMiu_HJdfw&list=UUGGcx95PMV2Ayq2id-HWNnw
Visualize all the originality of natural energy. It is present everywhere with frequency 7,83Gts. With this frequency nature calls all the energy and reduces to a total zero.
http://www.youtube.com/watch?v=rt1Xpx1jSBc&list=UUGGcx95PMV2Ayq2id-HWNnw
The link to Akula0083 and Ruslan is there !!!
Acca..[/font]
MenofFather
MenofFather
Here were Ruslan speaking about divice, who light two 75 light bulbs (https://www.youtube.com/watch?v=iyDaVspeeNE).
"...Блок питания -импульсник 3-6 ампер 12 вольт хватает вполне   Пропеллер от компа 12 вольт для охлождения.
Качер (не очень хорошая задумка) Бровина на частоту до 2х МГц !!! Надо подобрать по катушке в резонанс. Вот тут
пороаботайте головой   Например конкретно в этой системе 37,5 м длинна провода..."
"Power subly 3-6 amperes 12 volts is enought.
Kacher Brovina frenquency up to 2 megaherc!!! Need choose needed acording coil to resonance. ... for example in that system wire lenght is 37.5 meters [probarly he means output coil, not kacher]."
So key here is, I think, choose proper kacher for output coil. All kachers is diferent, ones resonate on 2 megaherc, others on 500 kiloherc, others on 1 megaherc and so on. Here just need trial and error way found proper kacher for output coil. Wound many secondaries, with diferent wire lenght for kacher. But wire lengh must be, I suggest, betwen 70 meters and 30 meters for 30-40 meters kapanadze style output coil.
