0 Members and 749 Guests are viewing this topic.
Jeg
Quote from: Void on September 19, 2014, 01:05:43 PM
Ruslan wrote the following:
I removed the inductor and do not want this garbage :whistle:  I have much better results without the inductor now.
If he can give the low frequency straight to the output coil and not inductively, then the same applies to the high frequency also. Something like this...
magpwr
Quote from: MenofFather on September 20, 2014, 05:45:36 AM
Here were Ruslan speaking about divice, who light two 75 light bulbs (https://www.youtube.com/watch?v=iyDaVspeeNE).
"...Блок питания -импульсник 3-6 ампер 12 вольт хватает вполне   Пропеллер от компа 12 вольт для охлождения.
Качер (не очень хорошая задумка) Бровина на частоту до 2х МГц !!! Надо подобрать по катушке в резонанс. Вот тут
пороаботайте головой   Например конкретно в этой системе 37,5 м длинна провода..."
"Power subly 3-6 amperes 12 volts is enought.
Kacher Brovina frenquency up to 2 megaherc!!! Need choose needed acording coil to resonance. ... for example in that system wire lenght is 37.5 meters [probarly he means output coil, not kacher]."
So key here is, I think, choose proper kacher for output coil. All kachers is diferent, ones resonate on 2 megaherc, others on 500 kiloherc, others on 1 megaherc and so on. Here just need trial and error way found proper kacher for output coil. Wound many secondaries, with diferent wire lenght for kacher. But wire lengh must be, I suggest, betwen 70 meters and 30 meters for 30-40 meters kapanadze style output coil.
Hi MenofFather,
We know that it's not logical that someone use 37.5meter wire to create kapanadze.Think about it using 1 or 1.5 or 2.5 mm sq wire imagine how thick this wire would be will never look the same as shown in photo.
Maybe it's the tesla coil which may need 37.5meter depending on the pvc pipe diameter which needs around 780...1000 turns using thin wire.The length don't make sense but we need to know the estimated
turns on certain diameter pvc pipe.
Jeg
Quote from: magpwr on September 20, 2014, 09:32:06 AM
Hi MenofFather,
2.5mm2 has 3.4mm outer diameter.
48T X 3.4mm= 16.3cm long.
It is exactly as it looks in the photo.. ;)
Void
Quote from: Jeg on September 20, 2014, 10:05:28 AM
Can't see where you guys are getting your numbers from.  :)
2.5mm^2 should be the cross sectional area of the wire.
A wire with a cross sectional area of 2.5mm^2 has a diameter of 1.78mm, plus whatever thickness the insulation is.
Area of a circle = Pi x r^2
2.5 = Pi x r^2
sqrt(2.5/Pi) = r
r = 0.892
d = 2x r = 1.78mm
Or you can use a chart like this:
http://www.engineeringtoolbox.com/awg-wire-gauge-d_731.html
All the best...
Jeg
Quote from: Void on September 20, 2014, 10:29:15 AM
2.5 = Pi x r^2
sqrt(2.5/Pi) = r
r = 0.892
d = 2x r = 1.78mm
All the best...
Its is exactly as you say, but you have to count the outer diameter with the insulation to calculate the length... and this is as i said 3.4mm
