0 Members and 85 Guests are viewing this topic.
Void
Quote from: Jeg on September 20, 2014, 09:26:54 AM
If he can give the low frequency straight to the output coil and not inductively, then the same applies to the high frequency also. Something like this...
Hi Jeg. There are of course various possible configurations. What I was wondering was if Ruslan had
explained in his latest video what he is actually doing or planning on doing.
All the best...
Void
Quote from: Jeg on September 20, 2014, 10:32:46 AM
Its is exactly as you say, but you have to count the outer diameter with the insulation to calculate the length... and this is as i said 3.4mm
Ok, I see. So you were including an estimation of the insulation thickness when you referred to the diameter
of the wire.
NickZ
  I've wound my Ruslan type air coil using thick wire, I don't know how thick it is exactly, probably is 2.5mm. It fits the 1 1/4" former tube to about the same width as what is shown in the images. Using the 48,48, 24, 24, 12,12 turns for the output coil, and 12, 12 turns for the input air coil.
  All the coils like the Kacher secondary as well as the yoke coils, and the air coil output coil can be adjusted for best resonance by adding or removing wire turns.
   It would of course be nice, if we didn't have to guess about the number of coil turns, former tube size, turning caps, and voltage and current levels, that are actually needed, as we may be doing now. This info and more should be included in the schematic.  The one that Ruslan has never shown.
  Ruslan says that Akula's schematic is not totally correct. But then Ruslan does not provide us with any working diagrams of his circuit, at all.
  It may also be that the diagram that someone else made of the Ruslan circuit that we've are looking at, may also not be totally correct, besides not providing all of the information needed to replicate it.
Jeg
Quote from: Void on September 20, 2014, 11:25:23 AM
of the wire.
The following equation is for accuracy maniacs like void and me! It is tested of course.
By giving the meters of the cable that you decide to use and the outer diameter of the wire including  insulation, you can calculate the exact diameter of the PVC pipe that you need for a 48-48 24-24 12-12 output coil.
R=(L-(1733.28 X D))/1055.04
R, the radius of the PVC pipe or any other material in mm
L, the length of the wire in mm
D, the outer diameter of the cable including insulation in mm
Example.
Length of the wire L=33.75m / 33750mm
Outer diameter of the cable D=3.4mm
Rpvc= 26.4mm So diameter is 2X26.4mm= 52.8mm or 5.28cm
In my case I used 35cm connection cables for each coil ends so in equation for a wavelength of 33.75m I put as L=33.05 m
magpwr
Quote from: Jeg on September 20, 2014, 12:23:59 PM
Example.
hi jeg,
Thanks for getting the numbers for this kacher portion of the device.
Around 33meters ...37m max of cable is required for kacher portion.
We would need to document this part so that there is no confusion
for others.2.5mm sq cable to be used on around 5.28cm diameter .
Upon getting deeper into don smith device.
Please take note to use only white pvc pipe .This needs to be applied for Ruslan or Akula device.
Base on research there is higher capacitance noted for grey pvc pipe as compared to white pvc pipe.
