0 Members and 85 Guests are viewing this topic.
NickZ
   Magpwr:
   It would also be a good idea to study Ruslan's latest video device, instead.
As it's quite different than the previous versions.  And the air coils on it are also connected to the yoke coils in a very different way.
   Ruslan's newest crt is now replicating the Akula air coil set up including the ferrite rod, (unlike the image shown above). His yoke's secondary coil (20 plus turn coil) is connected to the bigger 48,48 24, 24, output air coil, not to the 12,12 turn coils, as he had done previously. That's the way that I'm doing it. As there is much more output power when connecting the 20 plus turn secondary yoke coil to the big air coil, instead of to the 12,12 turn air coil.
  I will use the thick 3 turn yoke secondary coil's output, through a rectifier/capacitor, to provide the 12-24 DC voltage input for the Kacher circuit.
  What I'm still not certain about yet, is where and how the feed back path is connected and working. But first I want to get the new circuit finished for the
induction heater part of it. I will still use the Mazilli crt for that, for now, but a totally new one this time, including the 18v 5w zeners, and UF series cross-over diodes, connected to a brand new 12v 7ah battery.
magpwr
Quote from: starcruiser on September 22, 2014, 09:14:41 AM
@magpwr,
Can we determine the output of the kacher/telsa coil, voltage wise? is it only a few thousand volts? or is it 10's of thousands? I think it might be less than 10k, thus would a simple HV source be enough to create an impulse generator?
hi Starcruiser,
I unable to advise at this moment.
I prefer to take things one step at a time slowly and prefer to be 100% surely.
I am finding this video very very interesting about getting 2 resonance point from Akula tesla coil (Thick wire)
But i think i have just cracked this Akula tesla coil video which i have no understanding in Russian language.I am just using just pure instinct and i should be nearly 100% right this time.  :D :D :D 8) 8) 8)
http://www.youtube.com/watch?v=-rALEpvBQig
Base on video there is 2 resonance point (Just take a look at the drawing on the paper signal generator and scope both probes connected together and going into one end of thick tesla coil.The other end of tesla coil needs to be connected to earth(Important).This stage is very very important to determine the resonance points.Before even coming up with the necessary circuit to replicate the signal\frequency.
1)1.8Mhz which is provided by the transistor KT805  (Not mosfet or igbt).It is in the scope nanosecond range.
2)Another resonance point is the 27khz .
   This is provided by the Yoke core which is also a high voltage and frequency "27khz" generator.For this tesla coil in video yoke core needs to be driven at "27khz" or following the resonance point of the thick tesla coil in the khz range.
Basically this is the heart of the ou device which was revealed by Akula.
Basic fact-
This video would only make sense to those whom is "open minded or willing to try out of the box approach, something which was not taught in school",
electronics experience needed, own a scope,signal generator,diy a thick tesla coil. :D
MenofFather is there anything else i might have left out from this Akula video?
At this moment i have not studied the circuit hard enough to find out about the sync point.The last stage and the hardest stage to understand which can only happen provided if i am interested to build this device which would not happen after completing a "successful" Don smith China replication which was also reverse engineered visually. :D :D :D
starcruiser
@magpwr,
I understand the need to "sync" the coils frequencies. the 1.8Mhz versus the 27khz is not an even harmonic (not evenly divisible), you are around 66.666 (yes this was 6's across the board). one of them will need to be tweaked I would think.
But I am in full agreement that the coils should be swept and the resonant point frequencies noted. I did this when building my Tesla Coils, (solid state versions).
I think the real challenge for some will be to match the various coils (freq wise) to each other at a harmonic. I think this needs to be done in stages as you mentioned to ensure proper operation.
I think the air-core coil would/should be built first and then you would back into the numbers for the HV section since this section might be easier to adjust. I would think we need to watch the harmonic we are trying to hit as the power will fall off as the harmonic spread increases. I do recall from somewhere that the 13th harmonic will provide more power than the 11th or 14th etc... this is in sound, so it might be applicable to this.
Also with multi-layer coils they will interact with each other (you probably know this) and affect their inductance when adjacent to other coils versus a bare coil (no other coils near it). Thus my reasoning for the multi-layer first and work backwards to make the HV section and PSU match harmonically, as you can test the individual coils in the Air Core coil assembly and gather your test data and not worry about the drift caused by adding coils.
What are your thoughts?
Regards,
Carl
Void
Hi magpwr. You seem to have some things confused. As has been pointed out, Akula was talking about
the bifilar output coil (multi layer coil) in his video, and how he matches the tuning of the kacher/tesla coil to the bifilar output
coil. Both of Akula's first two devices seem to work on the same principle, as do Ruslan's devices. All indications are that
Akula started out by trying to duplicate Daly's device and made a few changes of his own, and Ruslan then later started
out by trying to duplicate Akula's devices and also based his devices on Daly's device and info, and Ruslan has been making some changes
of his own from there. All indications are that it is all the same principle, with just variations in implementation; if these
devices really do work as claimed, that is.
The circuit concept is basically an inverter driver driving an output coil, and the output coil assembly is also subjected to high
voltage pulses or a high voltage field in some manner. The earth ground connection is also a common element of this approach.
The questions for replicating are how to find the right coil tunings and frequencies and waveform synchronization, and of course
all the specifics of the coil arrangements. The approach I am taking right now is just doing basic experiments with this whole
approach to see if I can find a basic configuration that causes over unity results. Trying to decipher the devices by looking at photos
and videos and sifting through all the various bits of info and supposed schematics that various people are posting seems a fair bit
confusing at best. Not speaking Russian makes it even much tougher to try to decipher all the videos and info
floating around in Russian. ;)  Both Akula and Ruslan have probably hid some aspects of their devices and may well have
done a few things to try to keep people off the track as well. Presumably if these devices really do work, then
it should be possible for others to figure it out eventually, if Daly, Akula and Ruslan really did find ways to make this work.
All the best...
Void
Quote from: magpwr on September 22, 2014, 09:56:24 AM
Magpwr, something to consider. The so called China Don Smith replication video showed no power measurements at all (that I saw anyway).
Without proper power measurements there is no way to tell if the output power exceeded the input power.
Just looking at some light bulbs lighting up tells you nothing about input power versus output power.
If the China guy was getting overunity, then why not post up a follow up video showing a self running device?
It should not be that difficult if you really have significantly more power out than power in. Think about it. ;)
Has this guy posted a follow up video showing a self running device?
