0 Members and 575 Guests are viewing this topic.
T-1000
I will add my few thoughts:
The understanding how much energy is lost or gained due standing wave transfer and how standing wave receiver works might give some light. The Kapanadze style coil (48+24+12 canceling coils) have something to do with that field and also the introduced high voltage spikes to low frequency peaks already have long history in experiments of showing power input decrease while increasing output. Also the nuclear resonance have play there too and the electrons are splitted out from orbits around atoms are put into circuit then from the large area such as earth ground which are electrostatic source to replace missing electrons in nucleus after shocks.
Obviously it is long road of understanding to any experimenter with lots of failed circuits and knowledge gained... ;)
magpwr
Quote from: starcruiser on September 22, 2014, 10:26:11 AM
@magpwr,
I understand the need to "sync" the coils frequencies. the 1.8Mhz versus the 27khz is not an even harmonic (not evenly divisible), you are around 66.666 (yes this was 6's across the board). one of them will need to be tweaked I would think.
But I am in full agreement that the coils should be swept and the resonant point frequencies noted. I did this when building my Tesla Coils, (solid state versions).
I think the real challenge for some will be to match the various coils (freq wise) to each other at a harmonic. I think this needs to be done in stages as you mentioned to ensure proper operation.
I think the air-core coil would/should be built first and then you would back into the numbers for the HV section since this section might be easier to adjust. I would think we need to watch the harmonic we are trying to hit as the power will fall off as the harmonic spread increases. I do recall from somewhere that the 13th harmonic will provide more power than the 11th or 14th etc... this is in sound, so it might be applicable to this.
Also with multi-layer coils they will interact with each other (you probably know this) and affect their inductance when adjacent to other coils versus a bare coil (no other coils near it). Thus my reasoning for the multi-layer first and work backwards to make the HV section and PSU match harmonically, as you can test the individual coils in the Air Core coil assembly and gather your test data and not worry about the drift caused by adding coils.
What are your thoughts?
hi starcruiser,
It is always wise to start with basic coil layout without the additional coil at this moment reason being we need to know in the initial stage "the kind of waveform we are required to see"
in the mhz and in the khz range.The waveform at 1.8mhz and 27khz which we need to see was revealed in the video.
But in your DIY  tesla coil or the one which can resemble the tesla coil located on the left side of Ruslan device(refer to my previous attachment) as separate module would have another 2 frequency point which is unique to your coil.
Just download that very important video and study the required waveform that you should see for those 2 points mhz,khz.
"In the older video all the coils was combined together as multi layer with thick tesla coil as first layer which produce <1kw power.But Akula did mentioned about stability issue for the old device."
Void
Quote from: T-1000 on September 22, 2014, 10:42:18 AM
Not to mention various blown components and equipment when experimenting with high voltage circuits. :)
Hoppy
Or more than likely an input current decrease with increased output voltage being taken as a real power increase.  ;)
Will experimenters using only basic test equipment, ever really know and be able to demonstrate conclusively whether they have achieved true overunity.
magpwr
Quote from: Void on September 22, 2014, 10:36:37 AM
Magpwr, something to consider. The so called China Don Smith replication showed no power measurements at all.
Without proper power measurements there is no way to tell if the output power exceeded the input power.
Just looking at some light bulbs lighting up tells you nothing about input power versus output power.
If the China guy was getting overunity, then why not post up a follow up video showing a self running device?
It should not be that difficult if you really have significantly more power out than power in. Think about it. ;)
Has this guy posted a follow up video showing a self running device?
hi Void,
Yes you are right no measurement must be faked in all case.But think again the 12volts 7AH or less is able to power the 100watt x i think 16 bulbs.
The brightness of bulb is actually controlled by the variable high voltage generator 500volts...1600volts(120uf 450volts x 4 caps in series).If you take a hard look at the video and the forum.
I built variable HV supply 150volts-1600volts  using less parts with more power (270uf 450volts x 4 in series).The HV stage is 30AWG solid silver coated on oxygen free high conductivity copper wire which out perform my 26awg copper which i bought the bundle on the cheap <$15 from ebay.
http://www.youtube.com/watch?v=MknH42t0IGw
Try the same with the 12volts 7AH or less with 220volts 1000watt or 1500watt inverter see if that can even power on with those bulb connected.If you know what i am trying to say.
I do own a pure sine wave  50hz<1% tolerance 1500watt inverter by  the way with fully charged 12volts 21AH battery just won't even power on (error light on)with 1000watt halogen bulb.1000watt/12volts=83Amps(Not taken 88% inverter efficiency into account)
You can choose to believe in fake but i beg to differ on selected device i choose to replicate.Any failure would be my lost anyway.
I did not mentioned something about this Don Smith China.I'm just suspecting this is a gov funded project or some high level institute funded project.
Just think about it They are using $40USD Cree x 6 and convert into their money.I have not even started calculation with other components  into their currency yet.
Oh boy-You must have initially thought this is just some cheap prank video from China right.
My experience-if you can't handle multiple loses and failures then it's unlikely you would succeed in life.Just take that weak feeling and throw it out of the window. :D
