0 Members and 709 Guests are viewing this topic.
Void
Quote from: Hoppy on September 22, 2014, 11:03:14 AM
Will experimenters using only basic test equipment, ever really know and be able to demonstrate conclusively whether they have achieved true overunity.
That is trivial. Just make the device self running and put the device in a faraday cage if you want
to further eliminate the possibility of outside EM influences, although realistically you are not going
to power a bank of high wattage light bulbs from an external EM source unless you are right under or very, very
close to high voltage trunk power lines or really close to a high power radio station antenna, or very close by to a
very powerful tesla coil. Any decent wide bandwidth RF field strength meter would easily detect such super
strong EM fields existing around the device with the device switched off however, if that were the case. ;)
NickZ
  Some of us that have studied the Dr. Stiffler self running devices. There he talks about how to find the natural resonant coil frequency, as compared to the Spacial coherence factor, which is different. It is this Spacial Coherence resonant point (peak) that needs to be matched by the other coils, not to the first coils natural resonating frequency.
This idea may also be helpful to apply to the Akula/Ruslan devices.
  Each circuit will resonate at a different frequency. So, if you try to match the frequencies that Akula has obtained, or Ruslan,  it may not work the best for your device. As those specific frequencies may NOT be where to magic lies.
  Here (below) is a link to the latest Ruslan video, made 4 days ago.
I don't think that he has the Kacher output connected during the video, but I'm not sure about that. He also may have used a different type of wire for the Kacher's secondary wire this time, instead of the normal mag wire.
Hard to tell from his video though.
  Hopefully some of you can understand this Ruslan video better than I can.
https://www.youtube.com/channel/UCwVT-3hF29an4vZOz7nGOwg
  T-1000: What I still don't get is, how two different peaks (kacher and the induction heater frequency points) with two different frequencies, can match up on top of one another, when viewed on the scope. What's up with that...
Hoppy
Quote from: Void on September 22, 2014, 11:22:26 AM
I look forward to seeing this demonstration once a replication has been achieved.  ;)
Hoppy
Quote from: magpwr on September 22, 2014, 11:03:25 AM
hi Void,
Try the same with the 12volts 7AH or less with 220volts 1000watt or 1500watt inverter see if that can even power on with those bulb connected.If you know what i am trying to say.
Can you light an LED directly from a 1.5V battery?
Can you light an LED indirectly from a 1.5V battery?
Void
You can choose to believe in fake but i beg to differ on selected device i choose to replicate.Any failure would be my lost anyway.
My experience-if you can't handle multiple loses and failures then it's unlikely you would succeed in life.Just take that weak feeling and throw it out of the window. :D
Hi Magpwr. You seem to interpret people pointing out observations such as no proper power measurements
being done as an attempt to dissuade you from experimenting. That is not the case at all.
I was merely making an observation. I have not suggested I 'believe the device is fake'.  ;)
I just observed that in the video I saw no proper power measurements were done.
Something you may not be aware of is you can make various types of light bulbs glow quite brightly by applying
high voltage high frequency pulses to the light bulbs, but the average power may not be very high.
The down side is the light bulbs will likely burn out much more quickly than if powered as designed.
In my own experience, light bulb brightness is not a reliable indicator of power consumption.
Proper power measurements need to be done, or make the device self running.
This is based on a lot of experimenting. Take my observations for what you will. :)
