0 Members and 125 Guests are viewing this topic.
magpwr
Quote from: Void on September 22, 2014, 11:22:26 AM
That is trivial. Just make the device self running and put the device in a faraday cage if you want
to further eliminate the possibility of outside EM influences, although realistically you are not going
to power a bank of high wattage light bulbs from an external EM source unless you are right under or very, very
close to high voltage trunk power lines or really close to a high power radio station antenna, or very close by to a
very powerful tesla coil. Any decent wide bandwidth RF field strength meter would easily detect such super
strong EM fields existing around the device with the device switched off however, if that were the case. ;)
hi Void,
There was this simple experiment which was conducted in USA i think around 70 ..80 years ago.The photo was black and white. :D
They surrounded a small transmitter station with electrical cable couple of turns it was able to light a bulb i think nearly 100watt bulb dimly.
What you have mentioned is just "an assumption" at the moment.Something which isn't proven yet although it is possible, in theory which may work on how the fake was done. :D
Void
Quote from: Hoppy on September 22, 2014, 11:28:54 AM
I look forward to seeing this demonstration once a replication has been achieved.  ;)
No video could ever convince anyone who strongly believes that over unity is impossible.
Any video could potentially be faked. This has already been discussed and it is obvious anyway.
All I am personally interested in is trying to investigate over unity for myself. I am not interested in
trying to change the mind or beliefs of anyone else. People can and will believe as they are inclined to.  ;)
I hold no beliefs about such things, but I am personally open minded and curious enough to
be interested in experimenting in this area. Just a personal inclination. Everyone is free to do as they please
in this regard.
Hoppy
Quote from: Void on September 22, 2014, 11:54:34 AM
in this regard.
Agreed.  ;)
Void
Quote from: magpwr on September 22, 2014, 11:47:02 AM
Sorry magpwr. You seem to be misunderstanding much of what I saying, and ascribing
various motivations to my words which are not there at all. I think what I was saying was pretty clear
and also well established however.  ;)
starcruiser
Quote from: NickZ on September 22, 2014, 11:26:26 AM
  T-1000: What I still don't get is, how two different peaks (kacher and the induction heater frequency points) with two different frequencies, can match up on top of one another, when viewed on the scope. What's up with that...
the HV section (Tesla/kacher) is triggered on the peaks of the sine-wave (or near the peaks), this can be done with a one-shot multi-vibrator made up from a 555 timer that triggers the TC driver. you would use the single turn coil on a torrid with a few more turns (40) that feeds back to a zener diode to clip the incoming to say 5v or so and couple the signal with a capacitor to eliminate any DC component prior to the diodes that feed the one shot trigger ckt.
Regards,
Carl
