0 Members and 133 Guests are viewing this topic.
NickZ
  It has been the case for me that when using CFL bulbs, or LED bulbs (with their internal circuitry ungutted), on an Exciter/Kacher crt, that they don't last long at all. Their internal circuits burn out, almost immediately, sometimes, but it also depends on which bulbs, as the higher output ones can last longer.
  Even if a CFL bulb is gutted, their bulbs will still build up carbon inside the bulb, if connected directly to the bulbs, and eventually light with less brightness.
This can also be the case when using these types of higher voltage induction heater type of devices (with normal induction cookers ) when using the incandescent bulbs or halogen bulbs, over time,
  Hoppy: Good to see you back.
  Have you ever seen anyone able to light SEVERAL hundred watt incandescent bulbs from any external man made power sources, such as from radio frequencies, etz...     NO?
  TK said that he can light a LED bulb that way...  WoW!  Ha! Ha!
Hoppy
Quote from: NickZ on September 22, 2014, 12:09:33 PM
I've seen a couple of 60W flouro's powered brightly from overhead grid lines. Oh yes its possible but not the method Akula or Roman uses IMO.
starcruiser
Quote from: magpwr on September 22, 2014, 10:46:26 AM
hi starcruiser,
It is always wise to start with basic coil layout without the additional coil at this moment reason being we need to know in the initial stage "the kind of waveform we are required to see"
in the mhz and in the khz range.The waveform at 1.8mhz and 27khz which we need to see was revealed in the video.
But in your DIY  tesla coil or the one which can resemble the tesla coil located on the left side of Ruslan device(refer to my previous attachment) as separate module would have another 2 frequency point which is unique to your coil.
Just download that very important video and study the required waveform that you should see for those 2 points mhz,khz.
"In the older video all the coils was combined together as multi layer with thick tesla coil as first layer which produce <1kw power.But Akula did mentioned about stability issue for the old device."
@magpwr,
The multi-resonant points is what I was referring to, IMO you need to understand the resonant point of the primary coil on the TC then the resonant point on the Secondary, then re-check them once the coils are assembled as the resonant points change due to coil loading (from the Primary/secondary coils).
I see the diagram using the ferrite rod on the TC secondary output that feeds the Primary/antenna as the adjustment (inductor) to tweak the antenna SWR and coupling to the air core coil.
I also think it is important to check all coils inductance and natural resonance and record this info as you go. As far as waveform, a TC output should be sinusoidal for the most part since the secondary is resonating, the harmonic relationship is important IMPO to this device. We need to treat this as a RF device and tune it and treat it accordingly.
This is why I totally agree with you that if you want to play with this device the basic test equipment is required, Oscilloscopes, DVM's Signal generators, etc... otherwise how can you tell where you are at? Math only takes you so far in this as real world does have a habit of changing things on you.
We all have our ways of doing things to get to the same goal while not doing the same steps in the same order.
respect,
Carl
Regards,
Carl
NickZ
  How 'bout 2000 watts of incandescent bulbs?  Yes?
starcruiser
Please do not take the use of the word YOU meaning magpwr, but a general use of the word meaning others.
Regards,
Carl
