0 Members and 619 Guests are viewing this topic.
Void
Quote from: MenofFather on September 22, 2014, 12:53:57 PM
I try covert audio to word and you then with translator can translate every word.  ...
спасибо. :)
MenofFather
Quote from: magpwr on September 22, 2014, 09:56:24 AM
hi Starcruiser,
I unable to advise at this moment.
I prefer to take things one step at a time slowly and prefer to be 100% surely.
I am finding this video very very interesting about getting 2 resonance point from Akula tesla coil (Thick wire)
But i think i have just cracked this Akula tesla coil video which i have no understanding in Russian language.I am just using just pure instinct and i should be nearly 100% right this time.  :D :D :D 8) 8) 8)
http://www.youtube.com/watch?v=-rALEpvBQig
Base on video there is 2 resonance point (Just take a look at the drawing on the paper signal generator and scope both probes connected together and going into one end of thick tesla coil.The other end of tesla coil needs to be connected to earth(Important).This stage is very very important to determine the resonance points.Before even coming up with the necessary circuit to replicate the signal\frequency.
1)1.8Mhz which is provided by the transistor KT805  (Not mosfet or igbt).It is in the scope nanosecond range.
2)Another resonance point is the 27khz .
   This is provided by the Yoke core which is also a high voltage and frequency "27khz" generator.For this tesla coil in video yoke core needs to be driven at "27khz" or following the resonance point of the thick tesla coil in the khz range.
Basically this is the heart of the ou device which was revealed by Akula.
Basic fact-
This video would only make sense to those whom is "open minded or willing to try out of the box approach, something which was not taught in school",
electronics experience needed, own a scope,signal generator,diy a thick tesla coil. :D
MenofFather is there anything else i might have left out from this Akula video?
At this moment i have not studied the circuit hard enough to find out about the sync point.The last stage and the hardest stage to understand which can only happen provided if i am interested to build this device which would not happen after completing a "successful" Don smith China replication which was also reverse engineered visually. :D :D :D
"MenofFather is there anything else i might have left out from this Akula video?"
Tesla coil can work on any transistor. But in schematic KT805. Akula I not wery good understand. Ground cable  resonance of akula is 1.8 megaherc, Tesla coil also frenquecy must be 1.8 megaherc, and capasitor, who he circling (windings of coils he cal capasitor) also must be 1.8 megaherc.
Void
Quote from: MenofFather on September 22, 2014, 01:03:44 PM
Probably this statement is important:
"11:04 Почему с этой конструкцией очень просто и она очень стабильно получилось работать, потому что я все уже частоты заземления знаю. "
The frequency used would seem to depend on where you are located.
It seems Akula gave a hint there....
I believe Akula may mean the following in regards to this. The second and third layer
over the first layer adds capacitance (and inductance) to the overall output coil and lowers the resonant frequency
of the first layer windings.  You need to match these windings then for the desired overall resonant frequency.
If you combine with the above, you can see how it seems to tie together...
Hoppy
Quote from: Void on September 22, 2014, 01:12:43 PM
Has he discovered a devious way of stopping his electricity meter running!  ;D
Void
Quote from: Hoppy on September 22, 2014, 01:27:22 PM
Has he discovered a devious way of stopping his electricity meter!  ;D
You seem to see deviousness everywhere in relation to these devices however... ;)
