0 Members and 159 Guests are viewing this topic.
magpwr
Quote from: Hoppy on September 22, 2014, 01:27:22 PM
Has he discovered a devious way of stopping his electricity meter running!  ;D
hi hoppy,
Yes Akula did find a way to slow or stop his electricity meter using "Grid-Tie inverter" base on the Tesla coil tuning video-http://www.youtube.com/watch?v=-rALEpvBQig.
I have attached a photo in Akula space constraint room to show there is 2 Grid-Tie inverter(Upper unit is 1000watt) at the side of the wall.
In the past i have seen just 1 smaller version of the Grid-tie inverter likely only 500watt mounted at the side of the wall.
Please don't tell me he is using Solar cells in Russia to power the grid-tie inverter which would make me laugh. :D
I know all of us got different style in spotting things.You normally focus on device and it's connection.
But i like to observe surrounding and device to detect if there is any fake at play.
If there was fake would Chinese investor was needed to come all the way from China to Germany to be presented with few version of Akula device-Made in Russia.
Since i also understand Mandarin-Chinese as one of my 5 spoken language.There is obvious buying involved.
You just don't know what is happening that's all.Asia isn't the same as it was.
The island i am living in the heart of Asia have got a Moody rating of -AAA  (Simple terms the country i live in have got no bad debts) :)
Hoppy
Quote from: magpwr on September 22, 2014, 09:25:59 PM
hi hoppy,
Well, there you are. You are well on the way to free energy from your electricity supplier.  ;)
T-1000
hi hoppy,
Where do you see fully assembled device with bulbs attached in that video?
I can see only coils being tuned what are only part of final assembly...
magpwr
Quote from: T-1000 on September 23, 2014, 04:14:48 AM
hi T-1000,
The thick tesla coil video is likely one of the most important video which is revealed by Akula.
This is the transmitter portion.He is simply showing the easy way on what waveform to look out for.He started with 4.8Mhz but end up using 1.8Mhz(3rd harmonics maybe) and the 27khz (which is 66.666 times) lower than the 1.8mhz.
What we all have been seeing is just "blind replication" by others whom have failed miserably.Because none of us really knew what was the tuning requirement.
This video would likely be a real ice-breaker.
We can use this video as a guide since i know everyone assembled diy thick tesla coil would have unique harmonics for their coil.
In other words it won't be exactly 4.8mhz for a start but winding can be added or remove to get the peak at that frequency.If it's really that important to follow that first peak frequency 4.8mhz.
Ruslan version as we can see is there is 2 obvious portions which i have attached previously.
At this point there is nothing much i can advise base on my current observation.
MenofFather
11:10 Так, теперь определив частоту Теслы, определив частоту накопительного 11:18 конденсатора катушки 11:20, мы можем определить какую же гармонику нам выбрать низкочастотную вот эту 11:27 Да? Тут можно просто математически уже пойти, то есть, если это 1,7, 1,8 мегагерца, то есть высокая, то низкую уже можем кратную выбрать 11:44 и в ней уже запустить наши три амплитуды. 11:47  Почему три? 11:49 Давай развернём наши все эти штуки. 11:59 Как они рвуться. То есть, видешь, как они рвуться? 12:03 Как стараеться сама земля уже на более высоких частотах, вот под них и надо попасть. 12:09 То есть это просто да, можно математику: в три раза меньше, можно в 6 раз меньше, но я делаю не так, я всё таки вот так же проверяю на какой низкой частоте... потому что математика математикой, а по факту низкая частота может быть чуть в право, либо чуть в лево. 12:31 Вот, для определения низкочастотного колебания 12:35 вот этого LC контура, я проверяю точно так же. 12:39 Можно зделать, две-три таких катушек и убедиться в десять раз, допустим: три разные катушки такие, на сороковой, на сотой трубе. Узнать их резонансные частоты, а потом их прогнать к заземлению 15:53 полученому, всё равно упираешься практически в одни и те же частоты. 12:58 То есть теперь надо определиться с низкой частотой. С низкой частотой определяемся точно так же. 13:04 Ищем землю. То есть на какой у нас будет токовое движение. 13:11 Всё. Теперь уходим от нашей резонансной частоты 13:17 и переходим на очень низкие частоты. 13:22 И что мы видем? 13:29 И что мы видем? Я просто уже примерно сам знаю, вот она! 13:34 А в ней уже, в них, вот в них уже присутствует наш 1,7 мегагерца. Вот они! 13:44 Вот они красавцы! 13:45 Кстати, здесь низкочастотный порог очень большой на самом деле. 13:57 Сейчас... 13:58 Вот он! Красота какая! 14:01 Ну просто как вам определить, показать... 14:09 Находим, вот более стабильную частоту. 14:12 Вот она. 14:14 Нашли! То есть я убавил. А вот низкая частота. 14:21 Начиная от семи килогерц 14:23, 7,8 килогерц идём выше. 14:29 Нам нужна кратность частот! 14:33 Вот кратность, попали, более стабильная. 14:34 18 килогерц. 14:37 Вот самый удачный вариант 18 килогерц. Но я делал на 32. Сейчас посмотрим что у нас на 32. 14:51 Вот они. То есть порог до 32. Дальше уже падение амплитуды. 14:56 То есть, от 17 килогерц до 32. 15:01 То есть, вот этот контур, вот я и написал 15:03 17-37. 15:05 Всё. Это совпадает опять же с низкочастотным колебанием земли. 15:12 Они есть ещё ниже. 15:14 Но на воздушном трансформаторе ниже опускаться 17 килогерц смысла нет. Всё, теперь смотри. 15:24 Мы определились. 15:26 Здесь 1,7 мегагерца. 15:28 Здесь 1,7 мегагерца. 15:32 Здесь от 17 до 30 килогерц. 15:34 Сигнал синусойдальный поэтому он будет складываться 15:39 вот здесь. 15:43 Вот так. И всё упираеться только в частоты заземления.
15:57 Так, теперь какбы самое главное, что делает эту установку волшебной. 16:04 Пару слов и тебе будет, Виталий, понятно. 16:10 То есть, я заострил внимание, да, 16:11 что способствует накоплению? 16:12 Это не какие-то особые резонансы электронов. 16:16 Не какие-то фантастические частоты, конечно, это всё надо учитывать, за счёт этого имеем таковое токовое движение. То есть силу, которая это всё двигает. 16:27 Но как же происходит накопление, почему 16:29 буквально на 10-15 витках у нас получаеться амплитуда реактивной мощьности за 600 вольт переваливает, авкивная мощьность как раз получаеться. То есть а счёт чего 16:39 вот здесь происходит накопление. То есть всей этой системы. 16:43 То есть когда мы с совокупностью с землёй зделали Теслу мы имеем 16:50 вот такой синус. У нас. 16:57 Здесь. 17:02 Частота этого синуса, мы уже выяснили, здесь у меня, в районе 1,7-1,8 мегагерц. Что получаеться? 17:11 У нас получаеться фронт рабочий 17:14 вот такой. 17:17 Вот он. 17:20 Если его ещё и делить отрицательно земли... 17:26 Нас интересует только верхний полупериод. 17:28 Почему? 17:30 То есть 17:31 Здесь у нас работает чисто лёгкий водород. 17:37 Не более того. То есть фрон удара, проверено на 10 раз, вот. 17:43 Для чего нужна вот эта шняга? 17:47 Все её цепляют, не понимают, что они делают, для чего. То есть, к чему я это говорю? 17:54 Допустим всё, мы соблюли все частоты совокупности работы Тесла с землёй, мы получили нашу, долгожданную прибавку по движению, затраты наши токовые, уже будут намного меньше чем здесь. 18:09 То есть что ты, что сейчас, в принципе, ты, Виталий, на что, ты и стал. 18:12 То есть, какбы есть добавка, та которая, ну допустим мы загоняем нашу систему 18:19 в совокупности. 18:22 Загнали мы сто ватт в неё, в работу, мы какбы видем на выходе наши уже 400 ватт, ну грубо говоря. 18:32 То есть мы видем, что к нам 18:34 подключая вот эти токовые движения. 18:37 У тебя этого мало и такого нет, 400, там ватт 200 у тебя. 18:40 Ватт 200 у тебя работает на лампе. 18:46 О чём это говорит, о том что у тебя частично включаеться совокупность работы, то есть, у тебя это не подогнанно. 18:52 Вот. Подогнав мы как раз и увидем один к пятисот, 500 ватт какбы будет на выходе. 18:58 Но у нас не будет амплитуды. То есть токовым движением мы увидем, если ни как вот частично ловить 19:04 А именно всё в совокупности,  мы увидем прибавку. Возможно зделать самозапит. 19:12 То есть зделать свой инвертор расчитанный на 100 вольт, амплитуды как таковой выходной не будет.  19:16 И зделать самозапит. В этот режиме мы увидем, что установка просто работает сама на себя. Более того любое вмешательство в неё полностью глушит её. Теперь когда у нас всё совокупно 19:32 работает, мы имеем токовое движение в которое мы уже можем не влазить, наша задача 19:38 заставить работать вот этот накопитель, 19:40 так сказать, электронов из среды. То есть всё 19:45 вот это пространство заставить работать. 19:49 Вот. Большое внимание не буду делать, расказывать про все процессы, тебе будет и так понятно. 19:56 Что делает вот эта наша штучка? 20:00 Вот. Вот эта индуктивность 20:03 между нашей теслой и ударной 20:06 антены. 20:08 А делает она следущее: 20:09 Её 20:13 индуктиность как раз она подстраиваеться практически буквально находу и чуть-чуть ещё подстраиваеться когда даже включалось она, эта установка. 20:21 Что она делает? Индуктивность этой катушки какраз ровняеться у меня вот этому 20:28 полупериоду. 20:31 Вот этому. 20:33 То есть, соотвественно будет вот этому ровняться ударно. 20:37 Что происходит? А происходит у нас следущее: 20:40 когда у нас вот так амплитуда идёт. 20:46 То есть я её вот нарисую. То есть фронт у нас 20:49 он очень мягкий, вот такой, плавный. 20:52 Даже с учётом, что он 1,7 мегагерц. 20:57 Подключив вот эту индуктивность сюда 21:00 мы позволяем, вот в этот промежуток времени, накапливать этой индуктивностью ток. 21:08 А вот здесь уже, когда индуктивность накопила 21:11 ток мы видем вот такой выброс 21:14 на антене. 21:16 И вот именно этот фронт уже ровняеться 21:21 скорости соударения атомов практически равной скорости соударения атомов именно водорода в плазме. 21:30 То есть вот этот фронт, он уже наносекундный. 21:36 И вотименно эта индуктивность позволяет вот тут накопить 21:40 и произвести удар. 21:42 А затем уже плавный сход. 21:44 При чём ни как это не мешает работе тесле. 21:48 То есть вот эта индуктивность 21:49 съедает 21:51 вот этот фронт 21:52 вот до сюда где-то. 21:54 Здесь она уже накопила и полностью выдаёт бросок. 21:59 Причём вот эта какбы резинка 22:02 позволяет тесле в полном объёме практически набрать. 22:06 На тесле мы видем вот так набор, почти полный, 22:11 то есть она в полном резонансе, 22:12 затем она видет нагрузку, так как индуктивность, и она её свободно выдерживает. 22:18 И на антене мы видем вот такой бросок. 22:23 Вот это 22:26 фронт удара. В совокупности с работой общей. 22:31 И позволяет здесь появиться тому, Виталь, вот какраз тому что ты наблюдаешь в ударном своём разряднике. 22:40 То есть, вот здесь происходит резкое разделение зарядов и их продолжительное движение такое в совокупности с работой низкочастотного. 22:54 То есть вот какраз этот фронт позволяет зделать удар. 22:59 Почему он ефективней? 23:01 Я согласен, что этот фрон никогда не будет жёстче разрядника. 23:05 Но смотри: в разряднике у тебя, ты используешь ТВС-ку, да? 23:11 У тебя фронт удара у ТВС-ки, вот здесь разделение зарядоа у ТВС-ки выход, максимально 3, ну может быть 3,5 тысячу вольт. Твой разрядник бъёт 3000-3500 вольт. 23:24 У теслы же 23:27 вот здесь переваливает за десятки киловольт, то есть я измерял, когда ещё был счуп позволяющий лезть в 36000 вольт, так вот этот счцп 36000 вольт не выдерживал, то есть здесь больше было 36000 вольт. 23:41 То есть к чему я говорю? 23:46 Я  согласен, что вот этот период накопления уже будет на антене наростать, может уже будет вот тут нарост уже на антене 23:51 до 1000 вольт. 23:54 Но после того, когда индуктивность сожмёться выброс вот этот, сила, удар инерционный амплитудой за 36000 вольт. То есть, да мы имеем, фронт у нас короче, чем в разряднике, 24:10 но за счёт протяжённости амплитуды в десятки раз превышающей фронт разряда простого, простой ТВС-ки, мы выигрываем. 24:18 То есть получеться если ты ТВС-кой производишь вот этот фронт, который ты видешь индуктивный, да, такой нарост напряжения 24:26 всего  лишь 3000 вольт, то я испоьзую 36000 вольт, даже больше. 24:36 Вот так.
Here another part. If you find some errors and can not translate, then can write and I corect that errors or translate.
