0 Members and 325 Guests are viewing this topic.
Void
Quote from: starcruiser on September 23, 2014, 02:20:18 PM
@void,
Take a look at some of the stuff I posted above, this might help with the antenna/dipole statement. A dipole is nothing more than a rod antenna, the other side is the ground, this can be provided by a ground plane (rods or a plate that is matched to the wavelength of the radiator) or a ground connection, where does the ground go in these in most cases? thru the center of the tube, but I don't think this is a requirement. The wire length of 37.5m was to match the 1.8mhz wavelength (Ruslan), but the ground length becomes less of an issue when the operating frequency is lower.
I am quite familiar with radio antenna theory, and what you are saying does not match what Akula has
explained in his video regarding the two windings on the ferrite rod, and the large terminating coil, nor does it
match the definition of a dipole antenna. These components are not a 'dipole' antenna or a matching section,
as Akula has explained in his video. I suggest you watch Akula's video and read through the transcript of what he
says in the video. Yes, a tesla coil acts somewhat like an antenna, having voltage maxima and voltage minima nodes,
and the ground acts similarly to a ground for an antenna as well, but this is all separate from the components you were
referring to (the two coils wound on the ferrite core and the large terminating coil).  I will leave it at that.
All the best...
Void
Quote from: Hoppy on September 23, 2014, 02:39:44 PM
http://en.wikipedia.org/wiki/160-meter_band
More than possible!  ::)
Maybe Akula and Ruslan are making use of high power energy beams transmitted by alien UFO's
from outer space towards Earth. Every bit as likely, given there is no actual evidence for either  ;)
starcruiser
@void,
If you are then please look at this as I am and see if it makes sense. I am not asking if it matches Akula's statements. I have played with radio (CB, i.e. 11m) in my youth and built and tuned them so I know a few things too.
As far as what he says is not true then, he is just hiding what it really is. look at the items I am saying they represent, they are out there on the internet, go look.
TO me this is a tuned coil arrangement using a spark gap type transmitter and modulator circuit. I am not saying it won't work, I am saying what I see it is, at least to me, and how we can build and tune it to make it work properly. This device will have stability issues if the load changes too much since it depends on resonance.
Regards,
Carl
Hoppy
Quote from: Void on September 23, 2014, 03:27:59 PM
:o ;)
Void
Quote from: starcruiser on September 23, 2014, 03:36:41 PM
Hi starcruiser.  Akula definitely seems to be making use of tuned circuits, but beyond that
I personally don't know why this particular arrangement might produce over unity,
if it really does. I am still experimenting to see if I can find anything unusual about this setup.
Lots more experimenting to do however. :)
All the best...
