0 Members and 618 Guests are viewing this topic.
Void
Quote from: MenofFather on September 25, 2014, 04:52:03 AM
He say, that his tsla working on about 1,5-1,6 megaherc. First wounded secondary with ticker wire, then with tiner to ajust. And how we see in that divice no ferite road betwen kacher secondary and antena.
Thanks!
magpwr
hi MenofFather,
There is no thin copper wire on kacher which i assume is the receiver section.
On Ruslan device the  transmitter section which i mentioned just earlier in the few hours ago is just using thin magnet wire 18AWG...20AWG.There is no thick wire underneath.
Jeg
Yes it is a really interesting video! Eventually I hope that our Russian friends will describe about the most important points.
Menof and Mag why you think that there is no diode at Tesla coil? Even Ruslan drawn a diode in his explanation diagram.
Secondly, I know that katcher many turns coil, is not connected to ground but at transistor's base. Do I look a wrong circuit??
Well done to all of you guys... :)
magpwr
Quote from: Jeg on September 25, 2014, 05:03:17 AM
hi Jeg and everyone(whom is not a skeptic),
Let me explain the easy part first base on my current and latest findings which "some of us can digest to understand".
I have reattached pdf which is based on Akula translated voice related to Tesla coil tuning to simplify searching for answer.
This is the extract from the 2nd half of the translation in the pdf-
17:02 The frequency of the sine wave, we have found here with me, in the region of 1.7-1.8 MHz.
What poluchaetsya? 17:11 We poluchaetsya front working here is a 17:14. 17:17 This is
it. 17:20 If it is still negative, and divide the land ... 17:26 We are interested in only the
upper half-time.
Base on Ruslan video which was released only yesterday i extract a screen shot from the downloaded youtube video."At this point please download video to save time" ;)
Ruslan drew a sinewave which is likely representing the 17...32khz and at the top peak of sinewave he drew a nanosecond pulse (This might be around 10% duty for the 1.7 or 1.8mhz done by circuit).
Answer-
Comparing what Akula said and Ruslan drawing-
Now if you compared the upper half of sinewave base on the last sentence mentioned by Akula which i have pasted above and compared with Ruslan explanation via drawing which i have attached.
Both Akula and Ruslan explanation tallies which is good news.
We now know this nanosecond pulse will need to be to be produced/triggered at the peak of the sine-wave with the aid of the circuit which we will need to go into deeper at later stage but not now else things will be very confusing to understand.
Logically i believe that 9volts battery would have enough voltage & current  to likely power up the nanosecond generator circuit section using 5volts regulator for the signal generator which first starts sending pulse to Earth.
Then the rest of circuit would be powered up by the amplified current that is returning back to the device from Earth before even turning on switch leading to the bulbs.
Base on  Akula video title -#1
http://www.youtube.com/watch?v=bMdy4l-ZqeU&list=UU2aHNMDJzRW7YDd145_Pa2w
I have extract and attached the photo of Akuladevice and labelled mystery coil.Both Ruslan recent device and Akula device do have this coil.
I need someone to advise which is the mystery coil shown circuit diagram drawing which i am lost.
I have attached multi coil circuit diagram.Please advise.I believe this is the last outstanding coil to sort out before we can move on to the circuit.
Good news is the multi layered coil top most section which is 12,12 turns tallies with Akula device as attached since i have counted the turns.Strange things it seems 12 turns coil was wound on pvc pipe instead of overlapping onto the existing coil.
Now back to the topic jeg,
I would suggest to ignore the diode which was likely used as an example.Remember the trigger which only appear at the top half of sinewave only this is the way it is being done.
If you think there is a diode it's likely need to be a high voltage diode which which can handle 30KV maybe.
Don't forget about the current pulse which was sent to Earth with a imaginary diode in place how do you this pulse can be a bi-directional to return back to the device to self-sustain itself.
It is easy to go astray if your mind is thinking more complicated than the device itself.
Jeg
Quote from: magpwr on September 25, 2014, 06:03:37 AM
Dear Mag thanks for getting into trouble to explain some things. What follows is just my opinion. Don't take it as one way road..
First of all, nanosecond pulse generator by itself states one way pulses neg or pos doesn't matter.
The mystery coil perhaps is an output for 12 or 24V. Or even more possible for bringing the bifi coil to the correct resonant frequency by inductance adjusting...
The 12 turns coil portion don't look like it is separate from the other coil portions. But even if it is
there is not a problem. You see, this bifi has some unique characteristics. It has different portions with different inductances. The thin side has the lowest inductance and the upper thick section the maximum of its inductance. Notice that katcher's antenna hits at the low inductance portion which is the output of the coil. The higher inductance portion is for giving some resistance to the low frequency sinewave while it enters the coil, so to build it self inside the coil. In other words offers some magnetic resistance for the low frequency to be loaded. At the output portion we hit it with the high frequency pulses and so the low frequency while getting out of the coil 'sees' different impedance (lower than the one that expects). Imagine the output portion of the coil to operate as a high frequency switch, forcing the low frequency to be grounded some million times per cycle. Needs to be of a very low inductance... If you have this in mind you can even make two coils in series, one with high and the other with low inductance. Use your fantasy
About bi directional pulses and self sustaining operation... i dont quite understand this, as there is no connection between each other. In a tesla coil voltage goes up and current goes down. A reverse diode connected in series with this coil doesn't brake this flow. It just keeps voltage and current at the same signs during each cycle.
At the end, this device is simple only if you know what is the principal theory behind. Without this, things are Quite Complicated!
Hi GF... you put your fire and left us! But as you see it is still burning!!! ;)
