0 Members and 274 Guests are viewing this topic.
itsu
Quote from: magpwr on September 25, 2014, 06:03:37 AM
I need someone to advise which is the mystery coil shown circuit diagram drawing which i am lost.
I have attached multi coil circuit diagram.Please advise.I believe this is the last outstanding coil to sort out before we can move on to the circuit.
Magpwr,
for the mystery coil, see one of your own older post:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg417057/#msg417057
In there you can see its L3 = 50 turns (2x 25).
Eyeballing your picture above, i estimate indeed 25 turns (x2).
Regards Itsu
magpwr
Quote from: itsu on September 25, 2014, 07:48:03 AM
Magpwr,
Regards Itsu
hi itsu,
Thanks for pointing me to that post.
The mystery coil is indeed 25 turns.I i have done the count using the attachment.
Even more interesting finding the top is 25 turns the bottom give or take 28 or 29 turns.It's easy to see the bottom do have little more windings.
Multi coil setup initially is 12,12,24,24,48,48
What i can observe for the 12 turns layer is the bottom of the 12 layers is additional 1 or 2 layers.
(Reason-If you have ever done winding on pvc pipe especially if there is 2 layers the bottom need to have little more turns to ensure the top winding stay in position at the side)
So the Multi coil setup would be 12(top),14...15(bottom) 24(top),26...27(bottom)  ,  48(top),50...51(bottom)
Please download the attached Ruslan-Katuxa_2014-Coil Spec.
For everyone-There should be no doubt related to the winding spec at the receiver portion anymore.
To wrapped it up the electrical cable used is likely 2.5mm sq.Getting a 100meter bundle would be the best choice. :)
The PVC pipe diameter would be around 5.2cm to get 33meters.But with additional layer at the bottom this may increase to 35meters of electrical cable cable give or take.This is without taking into account
additional length of wire for connection.This would be close to 37meter give or take.
The pending item is the tesla/transmitter coil in which the winding or more proper inductance is unknown at this moment.
But this can be figured out via the Akula Tesla tuning video by looking out for the first peak waveform at 4.8Mhz by adding or removing windings.
18awg...20awg insulated magnet wire would be better choice rather than going for electrical wire which need more bigger pvc and hence more space is needed.
NickZ
   No ferrite rod, but,  low output in that device (not 2000 watts).
  edit:
  The above diagram of Ruslan's device was not made by Ruslan, and is not representative of how the Ruslan device is wound.
  Ruslan is not using the 48,48,24,24,12,12 turns that are shown in that diagram. As there is NO 12, 12 turns on top of the 24,24 turns. There is NO mistery coil, either, it's part of the 24,24 turns coil, not covered by electrical tape.
  Also there is not 2 times 25 turns for the L3 coil, there is 12,12 turns on it, or so.  All this and more make things very confusing.
  I think that it's best to follow what is being shown in the video of the Ruslan or Akula's device, instead of what is in the diagrams.
  You can try use the Kacher with, or without the diode. The diode will convert the kacher output to DC (half wave), instead of AC. It seams as that a DC output source is what is needed from the kacher crt. But, the Pulse Modulator may already have converted the kacher's output to DC, even without the additional diode. Or not?
magpwr
Quote from: Jeg on September 25, 2014, 07:22:20 AM
Dear Mag thanks for getting into trouble to explain some things. What follows is just my opinion. Don't take it as one way road..
First of all, nanosecond pulse generator by itself states one way pulses neg or pos doesn't matter.
The mystery coil perhaps is an output for 12 or 24V. Or even more possible for bringing the bifi coil to the correct resonant frequency by inductance adjusting...
The 12 turns coil portion don't look like it is separate from the other coil portions. But even if it is
there is not a problem. You see, this bifi has some unique characteristics. It has different portions with different inductances. The thin side has the lowest inductance and the upper thick section the maximum of its inductance. Notice that katcher's antenna hits at the low inductance portion which is the output of the coil. The higher inductance portion is for giving some resistance to the low frequency sinewave while it enters the coil, so to build it self inside the coil. In other words offers some magnetic resistance for the low frequency to be loaded. At the output portion we hit it with the high frequency pulses and so the low frequency while getting out of the coil 'sees' different impedance (lower than the one that expects). Imagine the output portion of the coil to operate as a high frequency switch, forcing the low frequency to be grounded some million times per cycle. Needs to be of a very low inductance... If you have this in mind you can even make two coils in series, one with high and the other with low inductance. Use your fantasy
About bi directional pulses and self sustaining operation... i dont quite understand this, as there is no connection between each other. In a tesla coil voltage goes up and current goes down. A reverse diode connected in series with this coil doesn't brake this flow. It just keeps voltage and current at the same signs during each cycle.
At the end, this device is simple only if you know what is the principal theory behind. Without this, things are Quite Complicated!
Hi GF... you put your fire and left us! But as you see it is still burning!!! ;)
hi Jeg,
It's hard for me to pick all sentence from the translated Akula Tesla coil tuning in pdf and present it.
There is a part mentioned about return signal from Earth back to device maybe form like double helix.
If you take a look at the Rulsan video where he use Amp meter on the earth connection cable to device.There is current movement but clamp meter isn't fast enough to capture since it's high frequency.
19:16 And to create one self
recording. In this mode, we will see that the installation just works on itself. Furthermore,
any interference with it completely suppresses it. Now that we all collectively 19:32
works, we have a current movement in which we can not intermeddle, our task force to
work 19:38 this one drive, 19:40 so to speak, of electrons from the environment. That is
everything 19:45 but this space to get to work.
"any interference with it completely suppresses it."
Maybe this explains why 2 large outer layer coil is used on device in order to prevent interference
Please i use only pure instinct for my reverse engineering especially if certain things is unknown and provided if i am interested to know."It's hard for me to explain this part"  :D :D :D
"Just kidding maybe"
itsu
Magpwr,
the "balun with ferrite rod" (L5 / 10uH) in your last drawing is in the latest Ruslan video a simple 2 turn air coil.
Adjust by bending.
Regards Itsu
