0 Members and 74 Guests are viewing this topic.
magpwr
Quote from: NickZ on September 25, 2014, 09:42:09 AM
   No ferrite rod, but,  low output in that device (not 2000 watts).
hi Nickz,
If device is a self-runner it won't matter if it's 750watt ,1000watt,1500watt especially if you can get it working for the first time. :)
magpwr
Quote from: itsu on September 25, 2014, 10:03:53 AM
Magpwr,
the "balun with ferrite rod" (L5 / 10uH) in your last drawing is in the latest Ruslan video a simple 2 turn air coil.
Adjust by bending.
Regards Itsu
hi itsu,
The interesting thing i noticed is there is few variation for Ruslan video.
There is one with a straight cable as well linking transmitter and receiver.
But i have noticed the 2 large outer coil is like cw,ccw formation for Ruslan device if it's a straight cable but i have not take a hard look into Akula video which is using ferrite and take a close look at the 2 large outer coil to compare and confirm.
The 2 turns looks like the latest version so we will need to stick with that.The slightly older one was a straight wire.
MenofFather
Quote from: magpwr on September 25, 2014, 04:59:32 AM
hi MenofFather,
There is no thin copper wire on kacher which i assume is the receiver section.
On Ruslan device the  transmitter section which i mentioned just earlier in the few hours ago is just using thin magnet wire 18AWG...20AWG.There is no thick wire underneath.
I wrote what Ruslan say. I beleave, that he say true. Here not wery tick wire on secondary kacher coil, but is first ticker wire, then tiner.
MenofFather
Quote from: Jeg on September 25, 2014, 05:03:17 AM
Yes it is a really interesting video! Eventually I hope that our Russian friends will describe about the most important points.
Menof and Mag why you think that there is no diode at Tesla coil? Even Ruslan drawn a diode in his explanation diagram.
Secondly, I know that katcher many turns coil, is not connected to ground but at transistor's base. Do I look a wrong circuit??
Well done to all of you guys... :)
About diode Ruslan explaing, how he think is in Akula divice, he bealive, that in Akula divice can be diode, who conected to ground. But I not think, that in akula divice is that diode.
Menof and Mag why you think that there is no diode at Tesla coil?"
Because in Akula schematic no diode. Ruslan no bealive, seems, that akula give true schematic.
" Secondly, I know that katcher many turns coil, is not connected to ground but at transistor's base."
Yes, and betwen bace and minus is 460 om resitor and minus is grounded. Trought this resistor electromagnetic field go  to ground.
MenofFather
Quote from: magpwr on September 25, 2014, 06:03:37 AM
hi Jeg and everyone(whom is not a skeptic),
Let me explain the easy part first base on my current and latest findings which "some of us can digest to understand".
I have reattached pdf which is based on Akula translated voice related to Tesla coil tuning to simplify searching for answer.
This is the extract from the 2nd half of the translation in the pdf-
17:02 The frequency of the sine wave, we have found here with me, in the region of 1.7-1.8 MHz.
What poluchaetsya? 17:11 We poluchaetsya front working here is a 17:14. 17:17 This is
it. 17:20 If it is still negative, and divide the land ... 17:26 We are interested in only the
upper half-time.
Base on Ruslan video which was released only yesterday i extract a screen shot from the downloaded youtube video."At this point please download video to save time" ;)
Ruslan drew a sinewave which is likely representing the 17...32khz and at the top peak of sinewave he drew a nanosecond pulse (This might be around 10% duty for the 1.7 or 1.8mhz done by circuit).
Answer-
Comparing what Akula said and Ruslan drawing-
Now if you compared the upper half of sinewave base on the last sentence mentioned by Akula which i have pasted above and compared with Ruslan explanation via drawing which i have attached.
Both Akula and Ruslan explanation tallies which is good news.
We now know this nanosecond pulse will need to be to be produced/triggered at the peak of the sine-wave with the aid of the circuit which we will need to go into deeper at later stage but not now else things will be very confusing to understand.
Logically i believe that 9volts battery would have enough voltage & current  to likely power up the nanosecond generator circuit section using 5volts regulator for the signal generator which first starts sending pulse to Earth.
Then the rest of circuit would be powered up by the amplified current that is returning back to the device from Earth before even turning on switch leading to the bulbs.
Base on  Akula video title -#1
http://www.youtube.com/watch?v=bMdy4l-ZqeU&list=UU2aHNMDJzRW7YDd145_Pa2w
I have extract and attached the photo of Akuladevice and labelled mystery coil.Both Ruslan recent device and Akula device do have this coil.
I need someone to advise which is the mystery coil shown circuit diagram drawing which i am lost.
I have attached multi coil circuit diagram.Please advise.I believe this is the last outstanding coil to sort out before we can move on to the circuit.
Good news is the multi layered coil top most section which is 12,12 turns tallies with Akula device as attached since i have counted the turns.Strange things it seems 12 turns coil was wound on pvc pipe instead of overlapping onto the existing coil.
Now back to the topic jeg,
I would suggest to ignore the diode which was likely used as an example.Remember the trigger which only appear at the top half of sinewave only this is the way it is being done.
If you think there is a diode it's likely need to be a high voltage diode which which can handle 30KV maybe.
Don't forget about the current pulse which was sent to Earth with a imaginary diode in place how do you this pulse can be a bi-directional to return back to the device to self-sustain itself.
It is easy to go astray if your mind is thinking more complicated than the device itself.
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/142798/image//
Unknow mystery coil is resonant coil, it resonate in series resonance with capasitor C on frenquency 17-40 kiloherc.
