0 Members and 28 Guests are viewing this topic.
NickZ
  If it weren't needed, Akula or Ruslan would not have used it.
  It makes a change in my Kacher's frequency and of the spark intensity, for me.
But, the main thing is, does it increase the device's output and bulb lumin levels?
Jeg
If you notice carefully you will see that these opposing field few turn coils on ferrite rod, differ of one turn. One of them is consisting of 5 turns and the other of 4 turns. My personal point of view was that initially akula tried by this way to make a some kind of phase difference between those two opposing fields, believing that after the extraction only a narrow pulse will pass from this ferrite rod to the output antenna. In practice didn't make it but it was still one proved and good way of lowering the frequency and tune properly the system so he left it as it is. The right question is still the same...
Quote from: NickZ on September 25, 2014, 11:35:04 PM
T1000 what is your opinion on this? Do you know by your experience if indeed there is an effective way of transforming a sinus to a narrow pulse of same frequency?
Something like this in the attached picture
Jeg
Does this have any chance? Or even without capacitor as the coil itself has its own capacitance.
magpwr
hi MenofFather,
Where possible just help to inform the Russian comrades base on attached photos on page Page 96 of the Russian forum.
It actually it using MC34063 to boost voltage say 12volts to around 18volts which then supply power to the TC4420 and TC4421 driver.This is obviously to power 2 x IGBT which requires higher gate voltage.
The source is PWM generator TL494.
Nothing much to decode for this circuit board.
http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=1710
But this circuit board would not have any relationship with the latest circuit which is using LM393,divide by 10 counter 4017,2 drivers IR2111,IR2113 likely there might be a 4046 PLL  in it which i am trying to figure out.This section seems to be used by Akula and Ruslan base on latest device.
Only the latest version uses 24volts for supply which i have attached for reference.The older version would likely be sensitive to load eg:bulbs but still works.
The newer version circuit Akula_30-06-2014.jpg would likely adjust according to the load which i have attached.
The older version i labelled as RuslanCircuit.jpg.(I am getting little mixed up between Akula and Ruslan but that's not really important)
I just zipped this 2 circuit board to retain it's original size without effecting the forum.
Void
Quote from: MenofFather on September 25, 2014, 04:52:03 AM
He say, that his tsla working on about 1,5-1,6 megaherc. First wounded secondary with ticker wire, then with tiner to ajust.
And how we see in that divice no ferite road betwen kacher secondary and antena.
Hi MenofFather. In Ruslan's latest video showing his schematic drawing, Ruslan is still including the
ferrite rod with the two opposing wound coils, between the kacher coil output and the 'antenna'. Ruslan seems to make
a comment about this in this video at about 4:46 (and a few other places) in the video. What does Ruslan say about this ferrite rod and opposing coils here in this video?
Is Ruslan saying he is using this component? It does not seem to be there in his previous couple of videos showing his device,
at least that I could see anyway. :)
All the best...
