0 Members and 574 Guests are viewing this topic.
starcruiser
Regards,
Carl
magpwr
hi everyone,
I have figured out how this older circuit labelled as RuslanCircuit.gif in attachment is functioning at the PWM generator stage.
If you noticed there is 17khz...27khz...37khz written in Russian somewhere in the middle of the circuit.
Upon studying the pin 5 of TL494 in circuit which the capacitor 1nf which normally would be connected to ground.Since this is connected to the 1N4007 diodes bi-directional which give around 0.7 volts.
This is then connected to 10ohms resistor in parallel.The 40 turns would likely be wound on a suitable toroid size not too large or small for the 3 turns thick electrical cable to go through 40 turns toroid.
This is already configured like a load detector which will raise or lower the voltage which will then alter the operating frequency of the TL494 accordingly.
Isn't this a genius approach used by Ruslan.
This ciruit diagram seem more related to this Ruslan video -
https://www.youtube.com/watch?v=7j7Y6sBnGV8&list=UUwVT-3hF29an4vZOz7nGOwg
NickZ
  Ruslan is using the ferrite rod to provide more output power to his version of the Akula second device replication. It is wound across the whole rod, not just 4-5 turns. This, his second to last device is his strongest self runner, (2.3kw), so far. Previous devices without the ferrite rod didn't have as high an output.
I don't see the rod wound in opposite directions, but maybe, as it's hard to tell from the video. Looks like the diagram is showing it wound in opposite directions.
  Was the diagram shown above drawn by Ruslan, or someone else?
  Ruslan's latest device (all in one bigger junction box) has not been shown working yet. It may possibly not be totally finished yet.
MenofFather
Quote from: Void on September 26, 2014, 08:23:12 AM
Hi MenofFather. In Ruslan's latest video showing his schematic drawing, Ruslan is still including the
ferrite rod with the two opposing wound coils, between the kacher coil output and the 'antenna'. Ruslan seems to make
a comment about this in this video at about 4:46 (and a few other places) in the video. What does Ruslan say about this ferrite rod and opposing coils here in this video?
Is Ruslan saying he is using this component? It does not seem to be there in his previous couple of videos showing his device,
at least that I could see anyway. :)
All the best...
"... Is Ruslan saying he is using this component?"
Ruslan say, that he not using this ferite road in this divice. But some times it needed, but sometimes it not needed, it is for ajustion kacher frenquency, let say. :)
4:46 "That thing in my divice not is, but it can be needed [in your divice]. ... Need experiment."
